MS4 Cam only dyno numbers
Lid
SLP Long tubes
3" dual exhaust w/ x-pipe/magnaflow 4x9's
LS6 intake
P&P TB
MS4 cam
3500 stall converter
Runs were done with an UNLOCKED converter. I'm very pleased considering no underdrive pulley and converter was unlocked. Made 390hp and 340tq.
Also found out, his LC1 was reading about 1 pt low on the AFR. I tuned it to a 12.8-13.0, just to find out it was a 13.8-14.0
The converter has noticeable slippage, even up around 6500 rpm. That's what he means by 'run unlocked' - the torque converter lockup solenoid was disabled (it seemed to bother the dyno operator, and whatever - I wasn't worried about the exact numbers, just their relation to one another as I tuned)
Anyway, the car is a beast. It breaks loose under 60mph with a full throttle punch (even with about 500 lbs of people in it)
And as I'm fond of saying about it - IT JUST KEEPS PULLING!
The torque converter lockup solenoid was disabled completely on these runs.
Ran a 12.3 @ 112.5mph tonight, on street tires, with about 76 degree weather and 88% humidity, btw.
*edit* which equates to about 415rwhp with his heavy *** in it (I put you as 300lbs, 3439lbs curb weight)
I run cars everyday. That run looks locked. Whether you're manually locking it or not, by the rpm it looks high enough to be locked automatically, and stay locked.
Furthermore, theres no hump in the torque band which would be there with an unlocked stall.
You'll probably walk me from a dig anyway.... 6-speed on nitto's.
