RESULTS TFS 215,Vinticator,Fast 90/90unported
I trapped on the norm on my old setup after it was completely dialed in right at 93 to 94with skinnys up front. I am trapping 96 now with heavy 17 inch TTIIs up front with 275 on my front Rims.
I am sure I can run some 6s on the 17s now. Had my seat not broken I would have had a slip. I only stalled the car to 2000 RPMS on the 7.0 run.
Actually I have a Yank PT4000 Converter. I had a PT4400 on my old setup. But I want to spray a 150 shot on the car once I get it dialed down to 6.80 on motor.
But this just goes to show DYNO NUMBERS mean nothing on the track
Here are two vids. They are really dark. Crappy Digital Camara. But its all I had..
http://www.youtube.com/watch?v=C86K1MI6N-4
http://www.youtube.com/watch?v=KENUDLIiqyQ
congrats SEB! but I also think once the motor breaks in a little you will see some better ET's along with learning the stall and proper tire pressure! I can't wait to see you on spray though!
I didn't realize you had out of the box heads also. Get that car to Vengeance as soon as you can. Let them get the heads done and port your intake. It wouldn't surprise me to see you pick up 50 horsepower and outrun my car at the track. Man, just call Ron and talk to him. Good luck.
They had TEA do what they called their TFK (Trick Flow Killers) port work on a set of LS6 heads. I can't arque the results but I'd have to defer to Ron as to exactly what they did. He'll gladly let on what the deal is and do the same to anyone's heads that asks him. I saw the flow numbers on the heads and they weren't world beating numbers but were strong nonetheless. 320+ on the intake and 270 or so on the exhaust. They just work really well with stock cubes and the Vindicator cam.
That looks to be a low low 11 to high 10 second pass. Not too shabby if you ask me. Tweak the setup with suspension, tires, and weight like you mentioned and that's easy 10s all day. Screw the dyno numbers.
Just out of curiosity, does anyone know what that 96mph 1/8 mile would ROUGHLY come out to 1/4 mile? 120ish, maybe a little more???
96 in the 1/8th is probably 124's.
A4's even locked are Horsepower Gobbling ******
Car has mid to high 6's in it (6.75-6.9) Needs more gear At least 3.73's possibly 4.10's
What are your 60"fts like? If you can get it to 60" in the 1.4-1.5 with that new power you will have a high 10 sec NA car
Nice Work BTW!!!
It will be nice telling people you only make 415rwhp then crack a 10.85@120 on there ***
Nice Work BTW!!!
