Top Bolt-On Dyno Results
Now have a Textralia Exo-Skel dual disk clutch , SOTP feels better .
My last and only track attempt resulted in a fried Ram HD clutch , run was a clutch slipping 2.37 60' , 8.75 @ 87.68mph 1/8th , 13.23 @ 111.16mph 1/4 . Raceweight was 3,650lbs at a little over 1/4 tank . Temp 82* F / 75% Humidity .
With most bolt-ons, my car laid down 354.19/372.63 Mods were:
Pacesetter long tubes
TSP ory
Hooker catback w/cutout
Self ported TB
SLP lid/Holley filter
TEXtralia OZ700
Year: 2001
Model: Camaro SS
Trans: 4L60E
TC/Clutch: B&M 3000
Rear+Gears: 10-bolt + 3.73s
Ft/Lbs+RPM: 393ft/lb @ 4200 rpms*
HP+RPM: 361hp @ 5200 rpms*
Mods: Hooker LTs/ORY/Exhaust, GMS Lid, HPTuned by me
* Locked numbers to compare with manual cars, see graph (or sig) for unlocked numbers
https://ls1tech.com/forums/dynamometer-results-comparisons/781681-dyno-ed-ss.html
But the LS1 did dyno 5rwhp less, unlocked (never tried locked). Mods: K&N FIPK II, OBX LT's, ORY, 3" Magnaflow, Powerbond UDP, NGK TR55's, .8mm JLB wires.
Conditions: Hot and humid, sweating in the shade.
Results: 320rwhp/335rwtq
Seems kind of low but the temps and humidity was horrible.
Year: 2002
Model: Camaro SS
Trans: T56
TC/Clutch: LS7
Rear+Gears: 10-bolt + 4.10s
Ft/Lbs+RPM: 389ft/lb @ 4100 rpms
HP+RPM: 368hp @ 5300 rpms
https://ls1tech.com/forums/showthrea...t=#post6065254
Year: 1999
Model: Trans Am
Trans: M6
TC/Clutch: Spec 3
Rear+Gears: 10-bolt w/ 3.42's
HP+RPM: 355rwhp
Ft/Lbs+RPM: 365rwtq
Ambient Temp: 101 Degrees F!
Dyno'd her outside in August AZ heat. This run was after a long cooldown. Mods and (#'s) in sig to
