Dyno Results With MS3
So you said, it doesn't seem like it has a big cam and may not be the MS3 on your first post...I would have to agree. But even with a 224/580 cam you should see mid 380's on motor.
2) Just because your injector duty cycle is maxxed out, it doesn't mean your injectors are. All it means is that to supply the neccessary fuel, your injector is held open for the entire combustion cycle. Combined with your A/F being all over the place, and the IDC capping, I would have put a fuel pressure guage on it. I would bet dollars to donuts that you are seeing a massive fuel pressure drop at WoT, and that is why your injectors are being told to stay open so long. You might want to look into replacing the worn out fuel pump, upgrading the wiring to the pump, and replacing the filter.
3) Get it retuned when the fuel problem is sorted, and bring the A/F down to 12.6-12.8 at WoT.
Holy Eyebrows!
To the OP, your A/F is all over the place, not sure who tuned it but theres no way i would hand a car back to a customer with a tune that bad, get it to someone who knows what they are doing and get it retuned asap
ALso you should be revving it to 6700 atleast for a pull bc you could tell that it was still climbing. Also it should be in 4th gear.
Like said above get a fuel pressure guage on it and see what kind of pressure your getting. Have you upgraded your fuel pump? Like a Walbro or anything? Also have you ever changed the fuel filter?
