View Poll Results: 360rwhp doable with cam only on stock manifolds? Options...
Small cam on stock manifolds FTW
20
42.55%
NO, get headers and duals
11
23.40%
Just get an UD pulley, ls6 intake, and other boltons
11
23.40%
Different route, please explain
5
10.64%
Voters: 47. You may not vote on this poll
Is 360rwhp doable with cam only on stock manifolds?
There have been several full bolt on cars do 360rwhp or close, I dont see why a cam'd car with stock manifolds cant do it...just gotta get the right cam...CheatR is your best bet, or have Patrick G or PredatorZ spec you a cam. I think you can easily do it with stock manifolds...but how come you dont wanna do headers? Long tubes are by far one of the best mods you can do to an LS powered Fbody!!
Post #1 in this thread
Headers with aftermarket catalytic converters wont keep him emissions legal?? Come on guys, whats the point of making aftermarket catalytic converters if they dont work?? I read his first post, still I ask, "Why dont you wanna have headers and make the power you should with a cam?"
By the way, nice numbers in your sig... That musta been a bad **** on the street. Ever spray it?
You can hit 360HP with bolt ons alone.
My car started with 298HP.
Lid
LS6 Intake
LS7 Clutch + LS2 Flywheel (loss of hp)
306HP
Ported throttle body
QTP Headers
2.5 Inch True Duals with x-pipe over axles
Cats (loss of hp)
Mufflers (I'm going for loss compared to bullets)
Tune
17x11 ZR1 Rims 315 Tires (more weight = loss of power)
349HP
If I added the underpulley, remove cats, have a LS1 or LS6 style clutch, gone bullets or used the stock 16 inch rims + tires, that'd easily account for 10hp+.
You'd pretty much still be within emissions, unless you live in Cali in which the longtubes are a writeoff...
Also of note 98-00 manifolds are CRAP. They can't flow for beans compared to the 01-02. Shorties will gain for him. The 98-02 uses a shorty style on the driver's side I think, and on the passenger side uses a LOG style. I know there are shorty headers for LS1 car that have CARB stickers on them, they will still be an improvement and keep him legal.
Lid
LS6 Intake
306HP
QTP Headers
Cats (loss of hp)
Tune
349HP
Thanks for the info sladex How much do you think i could gain with shorties on my 99? I can get some for 100 shipped or so. That would be a good buy?
And yes with california even if you have cats and longtubes and it passes the sniffer better then the stock manifolds and cats it is still illegal cause you have moved the cats from their origional location.
Ls6 Intake + shorties will put you in line with the 01-02 factory freaks. I've seen as high as 335HP on the dyno with a m6, and 305-325hp with auto.
An emissions friendly cam as mentioned by Predator-Z for stock manifolds or shorties will probably get you into that target range as long as you have the LS6 intake. The LS1 intake will choke a bit and rob as much as 15-20HP over the whole curve. Toss in the U/D pulley and ported throttle body and I think you can pull it off. You may also consider aftermarket cats and possibly true duals as well. I think cali emissions doesn't care what happens AFTER the cats anyways. At least that was the case for my car back in 01, dunno of any changes since I left there. To keep it passable, you'll need to run it out the back though, so consider the BMR panhard relocation kit to get the pipes over the axle.
You will need a tune to keep it emissions passable.
#32
so my list needs to be:
cam
springs
pushrods
ls6 intake
shorties
duals maybe or good everything behind the headers (best legal system) maybe removable cats, maybe.
p&p throttle body
free mods
underdrive pulley
Dyno tune
#33
Just make sure you choose a cam with a pretty large split, I am no cam expert but I would say at least 10deg more exhaust dur than intake. Just as shown in the chetr cam specs, you will need a big exhaust duration to band aid the poor flow in the exhaust.
#35
No matter what his emmissions are under the sniffer, he can't have headers to pass the visual, I don't think. I don't think you can't move any of the stock parts' locations. I think he can get only shorty headers, and why bother with those.
#36
We just finished a cam and UD on a 99 Vette, made 353. The cam is so mild, we didnt change the valve springs, and it doesnt even lope. Hell, the customer drove it untuned for 2 days with zero driveability problems and no CEL.
As for gains, we started at 318, so we gained 33 hp. With even a slightly more aggressive cam, we could have run right by 360.
#37
This is what I would recommend:
214/228 .595/.588 115+2 LSA
-6>IVO
40>IVC
51>EVO
-3>EVC
117>ECL
-9* Overlap
This is a custom XFI/XE-R Comp cam lobes, very tame, will work on PP duals, no headers needed, 700 idle, pass any emmision test, peak around 6000rpm good till 64/6500
-6>IVO
40>IVC
51>EVO
-3>EVC
117>ECL
-9* Overlap
#38
We just finished a cam and UD on a 99 Vette, made 353. The cam is so mild, we didnt change the valve springs, and it doesnt even lope. Hell, the customer drove it untuned for 2 day with zero driveability problems and no CEL.
-6>IVO
40>IVC
51>EVO
-3>EVC
117>ECL
-9* Overlap
-6>IVO
40>IVC
51>EVO
-3>EVC
117>ECL
-9* Overlap
thanks for the specs i will consider that also, i have time to think about what i want to do and that is usually the best. But i will strongly consider that i always liked the custom idea over an off the shelf cam.
#39
216/220 .561/.530 113+3lsa..you can run PAC or Comp beehives,and won't have to rev it to the moon to make power..-8 degrees overlap will give you a mild lope,kick the idle up it will sound like a stocker..
