02 Maggied TA
Old Apr 16, 2008 | 01:34 PM
BADSZ28's Avatar
Well no matter what, a better spring is overall better. I don't want to seam like I am arguing that point. I am just saying that an upgrade is not really worth it unless you are upgrading the cam too. You will not see noticeable gains unless you rev it past 6k. But if you are changing the springs, you would be stupid to not do the cam too. Cam swap is faster and easier than spring swap. And you would have to pull the covers and rockers to do the cam later on anyhow.
Old Apr 16, 2008 | 04:31 PM
yotaman96's Avatar
Great numbers garrett!! Glad everything is going well for you.
Originally Posted by stevegrizzle
noone is asking the important question, why in the hell would you go throught all that and not have proper boltons?!?!?
What proper bolt ons? If that's the power he's looking for, why do anything else? There is no such thing as a "proper" bolt on for a maggie. If he decides he wants more then he can do more.
Old Apr 16, 2008 | 07:15 PM
AINT SKEERED's Avatar
I know of a turbo ls1 that chased his tail with a valve flutter over 7 psi of boost. this was with patriot gold springs. he shimmed them to 1.75 installed hight and no more flutter at 6500 rpms as it was not letting him above 5600 before. he is now running 14 psi and no valve flutter.
Old Apr 16, 2008 | 08:13 PM
stevegrizzle's Avatar
So stock exhaust is efficient with F/I? Wow
Old Apr 16, 2008 | 09:20 PM
68birdls1's Avatar
Obviously if he put down the numbers that he did. Those are damn good numbers for nothing else but the kit so I would say that the stock exhaust is efficent.
Old Apr 16, 2008 | 10:59 PM
raptorws6's Avatar
Very nice #'s.
Old Apr 16, 2008 | 11:38 PM
yotaman96's Avatar
Yes, people do it all the time. The maggie was designed to be a bolt on and go supercharger.
Old Apr 17, 2008 | 07:19 AM
ScreaminRedZ's Avatar
registered user
I think we can all agree that it'd make more power with an exhaust upgrade. That being said, there are no preordained bolt-ons needs for a blower.
Old Apr 17, 2008 | 10:16 AM
sho-me speed's Avatar
Closed ex-Sponsor Account
What cam was this particular turbo car running?
Old Apr 17, 2008 | 12:03 PM
BADSZ28's Avatar
Yeah, what cam specs? Deff not stock.
Old Apr 17, 2008 | 01:12 PM
yotaman96's Avatar
I believe everything is stock except an slp loudmouth catback and the maggie.
Old Apr 17, 2008 | 01:33 PM
  #32
02 Camaro SS's Avatar
Those are ridiculous numbers. I love these LS1s with maggies.
Old Apr 17, 2008 | 01:37 PM
  #33
b.lee's Avatar
badass numbers.
now go beat up on some slowstangs.
Old Apr 18, 2008 | 02:14 AM
  #34
PREDATOR-Z's Avatar
Originally Posted by BADSZ28
Again, boost will not let the valve hang open and unless you are reving past 6200, you will not have float on a stock cam with stock springs. Actually you are more likely to bust a spring reving past 6200 than you are to float the valve with stock cam and springs.
Do no not waste money on springs unless you are doing a cam swap.
Bad, you are arguing a lost cause, I have experienced float on a SC setup and stock springs. Stock LS1 springs can float (if tired) on just a stock cam.
I cured me float by adding 02 LS6 springs/
Shortcuts and unnecessary savings I never understand. 6000+$ on a maggie and wimp on a 100$ set of springs and a bit of sweat
Old Apr 18, 2008 | 08:14 AM
  #35
Dave 96TA's Avatar
LS6 springs are only $52
Old Apr 18, 2008 | 06:19 PM
  #36
PREDATOR-Z's Avatar
That is what I mean. Add, new gasket it will be close to 100
Old Apr 20, 2008 | 06:57 PM
  #37
98camaroLS1M6's Avatar
Congrats, I like that torque!
Old Apr 20, 2008 | 07:49 PM
  #38
The Alchemist's Avatar
UNDER PRESSURE MOD
Why waste money on springs when the piston is more than happy to help push the valves closed.
Old May 1, 2008 | 02:04 PM
  #39
garrett3's Avatar
Wow! some of you ladies need to calm down. No one said I was finished with the car. I am planning a forged motor with heads,cam........ but for the time being it was fun to see how much the blower would make all by itself.
Thanks for the comments.
Old May 2, 2008 | 10:57 AM
  #40
JakeFusion's Avatar
Super Hulk Smash
I'll have to say that going with new springs on any boosted car is a good idea. I've seen it on everything from LS1s, to Supras, to Fords. No theory needed when the real world says better springs + boost = more power.
Also, headers are not a requirement for the Eaton blower on the LS1. It usually adds little to nothing. Save your money for a meth kit.
