PRC 5.3 TR224 Results....
Old May 3, 2008 | 09:04 PM
Parrothead497's Avatar
Default PRC 5.3 TR224 Results....
So I finally had my car dyno'd after 4 months of waiting after my H/C swap. I have a 98 6-speed with PRC 2.5 5.3's and a TR224 on a 114 LSA, LS6 intake, ported TB, 42lb injectors, and all supporting bolt-ons. Also have a TSP catted-Y with Pacesetter LT's and a dual dual catback. I did a best of 395/375 after 9 pulls. I was hoping for a little more but guess I can't be disappointed. Does this sound about right???? Any ideas where I could gain some more power? I was thinking maybe cutouts??
Thanks for your input.
Old May 3, 2008 | 09:09 PM
LS1 SPEED's Avatar
no dyno queen, but doesn't seem far off to me with the mods
stock rearend?
stock gear?
if you are looking for a bit more power remove the cats, get a cutout & I'm sure you would see 10-20 rwhp
Old May 3, 2008 | 09:14 PM
Yes, stock rear and stock gearing. Any ideas on what I would gain with a ported fast 90/90?
Old May 3, 2008 | 09:22 PM
Full-Force's Avatar
I would think it would be higher with heads. Every dyno is different but one car that I tuned put down 388 cam only with 4.10's and 18" wheels with the 224 cam.
You need a good tune.
Old May 4, 2008 | 07:53 AM
LS1 SPEED's Avatar
yes..all dyno's differ and that's why I didn't say it is too low
We have had a few on our dyno here and there that are 20-30 lower then norm with a particular combo, but they run as good if not better then the higher dyno cars at times.
did you pre-dyno the car? We try to do this a lot more now since some just start lower, but the gains are all the same at the end of the day.
I would say maybe 10ish with a 90/90 with this milder combo.
get it to the track and see how it does
Old May 4, 2008 | 10:50 AM
Ryan02SS's Avatar
Your setup is very close to mine. I have 4 year old Patriot 5.3's and I would think the PRC 5.3's would blow them out of the water. Numbers are in sig...
Old May 4, 2008 | 12:34 PM
30th t/a's Avatar
I would figure 415-430rwhp with those mods. So yea Id say its low. If it were me, I would compare it to another dyno just to see how it compares.
Old May 4, 2008 | 07:00 PM
LS1 SPEED's Avatar
good suggestion on the dyno
Old May 4, 2008 | 07:15 PM
cookba's Avatar
try putting on a 85mm MAF and see what that will gain. 2004 Z06 MAF or a SLP MAF
Old May 5, 2008 | 11:35 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
With cats & through the exhaust it's still a little bit lower than I would guess. What compression did you set it up with? You might consider putting a cut out on it just to see where she's at with a good exhaust.
What kind of air fuel & timing did she have?
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old May 5, 2008 | 12:26 PM
99ccz28's Avatar
That definitely seems low. I have pretty much the exact setup as you only in an A4 and I made 380 with a bad transmission.
Old May 5, 2008 | 01:09 PM
1989GTA's Avatar
Every dyno is different like was said above. I would not be too concerned as you are in the ball park of where you should be.
Old May 5, 2008 | 01:13 PM
regblkss's Avatar
I did same hp with a a4 on a dynojet. very sim mods to. seems low to me.
Old May 5, 2008 | 06:01 PM
Yea,
I felt it was a little low myself. Im not too concerned, but Im not going to lie I wanted to break 400. Im not sure where the AF ratio was but I do know the timing was at 27.
Old May 5, 2008 | 06:14 PM
davered00ss's Avatar
Moderator
Berore #'s would be good to know. They do seem low. I did 38X rwhp/370rwtq with the TR224 & bolt on's. 430rwhp/403rwtq after the AFR 205's.
Old May 5, 2008 | 06:17 PM
snake charmer's Avatar
my cam is a a 224 / 228 114 with 243s and a fast 90 ported also byme and i just did 439rwhp . check link in sig for the dyno chart . i would say you would gain 15-20 with a fast 90 .
Old May 13, 2008 | 11:03 AM
SpeedWorld's Avatar
Very low #'s. I just dyno'd my cam only SS. TR224 and full bolt on, stock ls6 intake...car made 390hp/380tq. With those heads I would expect to be around 425rwhp/395tq.
Old May 14, 2008 | 08:57 PM
Im going to take the car to get dyno'd again. This time ill take off the 19 inch c6's with runflats and run the car cool. The 395 was after 9 runs on the dyno, so I think I might have lost some power with the heat. I'll keep everyone posted on the new numbers
Old May 14, 2008 | 09:25 PM
firefighter813x's Avatar
Good luck bro. Look at it this way, at least you already have a nice set of heads. If you ever swap out to a bigger cam you've got the hard part done. Like everyone has said, it does seem low. How does it drive? Have you considered another tuner?
Old Sep 8, 2008 | 03:10 PM
SladeX's Avatar
It could be that the dyno is running low numbers too,
I've been on different dyno's and my lowest is 364HP/362ft/lb
On another dyno was is 372HP 370ft/lb.
And just after the cam install and tuned are the numbers in the sig.
