Dyno guesses???
Old Jun 28, 2008 | 03:09 PM
toneloc60's Avatar
Default Dyno guesses???
Monday is the big day. My engine should finally get on the dyno. What do you think it'll make at the flywheel? It's built for nitrous, but will be N/A Monday.
LSX 441ci 11:1 cr
6.125" Lunati Pro Billet Rods
4.125" Compstar Callies crank
4.125" custom Wiseco pistons for nitrous
Meziere street version w/p
LS7 heads ported and polished with Ti and sodium filled valves
LS7 carb intake
950 Quick Fuel Technologies carb modified for E85
MSD coils and wires
Harland Sharp custom made roller tip rockers (still 1.8:1)
Melling high pressure and high volume oil pump
Kook's 2" primary headers w/LS7 flange and 3 1/2 collectors
MSD ingnition controller for LS2
Cloyes double roller timing set
Custom Comp Cam: (Everything is based on 1.7:1 rockers, I have 1.8:1)
Gross valve lift Intake .623 Exhaust .623
Duration Intake 254 Exhaust 266
112 Intake center line
114 lobe separation
I should've been on the dyno Friday, but had the wrong crank sensor. I have my fingers crossed for everything to be right Monday.
Old Jul 3, 2008 | 12:56 AM
toneloc60's Avatar
Here are the numbers. Sorry, the graph isn't scanning in very well. Yes, these #'s are at the flywheel.
Old Jul 3, 2008 | 02:19 AM
krazy4's Avatar
Nice numbers man!
Old Jul 3, 2008 | 02:34 AM
toneloc60's Avatar
Thanks.
Old Jul 3, 2008 | 06:50 PM
gator's 99TA's Avatar
very impressive!
Old Jul 3, 2008 | 08:38 PM
bad6as's Avatar
743hp 634tq
dam....
Old Jul 3, 2008 | 10:25 PM
347fairless's Avatar
Sweet numbers man.
What is with the A\F?
Old Jul 3, 2008 | 10:28 PM
toneloc60's Avatar
Originally Posted by 347fairless
Sweet numbers man.
Thanks. I'm running on E85. I kept the compression low enough for pump gas, but am choosing to run E85 for the higher octane at lower cost. It'll be needed once I get the N20 hooked up.
Old Jul 3, 2008 | 10:52 PM
MYSTIC-1SC's Avatar
impressive
Old Jul 5, 2008 | 11:21 AM
ramairws6's Avatar
Sweet dude!!
Old Jul 6, 2008 | 05:27 PM
Firehawk441's Avatar
Looks like solid #'s. Those big heads love cubic inches. Good luck with it.
Old Jul 6, 2008 | 08:41 PM
Gordon0652's Avatar
Great numbers!
Looks like that engine is running a little rich from the dyno sheet?
Old Jul 6, 2008 | 09:49 PM
toneloc60's Avatar
Nope, it's running E85.
Old Jul 7, 2008 | 12:05 AM
Gordon0652's Avatar
Bad *** then!
Old Jul 8, 2008 | 11:33 PM
Fifedogg's Avatar
That thing is gonna be a beast!
Old Jul 15, 2008 | 10:47 PM
GrannySShifting's Avatar
Looks pretty healthy, shoudl be able to see some 9s even in a heavy car
Old Jul 17, 2008 | 10:16 PM
beardWS6's Avatar
SWEET numbers man. That is going to fly!!
Old Jul 20, 2008 | 01:22 PM
PONTIAC SLP's Avatar
kill me man with those killing numbers !! beaaaaast
Old Jul 28, 2008 | 02:54 PM
toneloc60's Avatar
So, I blew the engine in my DD yesterday. Do you have any idea how tempting it is to have this engine sitting in the corner eye balling me?
