AFR 205s, Fast 90/90, 230/232 (take two)
Hey fellow members. About 4 months ago I dynoed after installing H/C/I package. The numbers where a little dissapointing.
After consulting Tony Mamo, who helped me choose my setup, I went back to my tuner and we did some adjustments. The results speak for themselves.
Anyhow, While i was there I thought we might as well tune for the N2O. We took out 6 degrees of timing, and with the help of NANO kept a constant bottle pressure of 1050PSI. Here are the results for the 100 shot.
Needless to say, I am extremelly pleased with the results. I want to thank Tony for all his help especially the porting of the 90/90. I would also like to thank Matt and Brian at RPM (lewisville) for having the patience to get the tune right. Altogether I think we made 6-7 NA pulls, and 4-5 N2O pulls to get everything perfect.
nice NA #'s
The nitrous tune needs some work by the looks of the A/F. The constant bottle pressure should have made a much more consistent A/F. The low rpm is very lean and higher rpm very rich which is unsafe IMO.
Thanks for the input. I thought being rich in the high RPMs was supposed to be safer???? I don't think the low RPMs were all that lean, but I will discuss it with my tuner.
If thats the right A/F ratio there is still a bunch left in this thing....
Better results are achieved leaning the engine out as it approaches peak power....the most fuel needed is usually around peak torque where the engines volumetric efficiency is the highest (I usually like to see 12.5 - 12.8 in that area for best results). As the engines starts heading towards its power peak (and its V/E starts falling off), it actually likes less fuel. I usually like to see it drift towards 13.0 - 13.1 approaching peak power and above and sometimes slightly leaner as every combination is a little different (if you want to get the most out of it and all of this is predicated on the fact we are discussing N/A engines of course).
If you want it "safer" keep it in the mid 12's across the board (you may only give up 3-5 RWHP there) but by the looks of your A/F curve you might be in the 11.0 range (or worse) approaching peak power. As LS1 Speed mentioned....too rich can be just as harmful as too lean.
Get some actual numbers....has your tuner worked much with these types of combinations? I find it strange that he would send you out the door with the A/F ratio diving pig rich like that as the engine RPM's higher unless thats what you specifically told him to do.
Barring that the numbers look a whole lot better and if there is any left on the table its even sweeter.
Tony M.
PS....Call me if you need some input....Im afraid to ask how much timing
Tony M.
and i agree, that from peak tq to peak power would benifit by leaning out a tad. and its hard to say on that nitrous run, the afr heads south in a hurry like you would see with a low/cold bottle. but you said you had a nano?? look at some of the earlier runs and see if they are the same. maybe you were getting low on juice. if not then well. i would try to flatten that out. def some left on the table on the bottle. and 6 degrees for a 100 shot. that alot.
nice combo and power tho. alittle tweeking and should be a monster
Nice gains. You may find that you can make more power with a little less fuel and a little less timing NA. Correct fueling seems to make a bigger swing on power production than timing with these LS1s.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
if you hit the limiter the graph will spike/bounce all crazy. its all how you start/stop recording the run oposed to when you let out of it or hit the limiter. its not a trick but not acurate data either. claiming that little spike at the end of a pull as peak power is not real honest power. ....
I pull to the limiter quite regularly but don't get that spike that increases peak.
I only mentioned it because 3 out 4 people here will read the peak numbers posted, glance at the graph, and then read on without realizing that the numbers came from a spike, and they are not the true peaks recorded/observed/produced by this setup.
Ok, I have an appointment at 9:30AM tomorrow at another shop. Will make 3 pulls to check the current tune and go from there depending on whether or not adjustments need to be made. I Will be sure to get a better A/F graph. Personally, I would be suprised if it needs significant adjustments, but a 2nd opinion is never a bad thing.
So, tomorrow I should look for an A/F ratio (NA) of somewhere in the neighboorhood of 13.0 at 6400RPMs, Right?
What about for the N2O tune? The main thing I am looking for on this tune is "safety". I don't want to exceed 550rwhp, because i think that is about the limit for the stock bottom end. So what should my A/F be like on the nitrous tune.
