JPR S2 H/C Package **Part 2** SLP Dyno Results
Old 08-25-2003, 10:53 AM
BLK01WS6's Avatar
Default JPR S2 H/C Package **Part 2** SLP Dyno Results
Well after reading posts on here for the last two weeks about everyone doubting dyno numbers, I took it upon myself to do an independent dyno session. This morning I took the car to SLP in Toms River. They put you in a glassed off room and keep you away from the car. My car put down 456.1rwhp and 406.2ft-lb. SAE corrected with 3 degrees of knock retard across the band on the second pull. Unfortunately Joe wasn't able to be there to see this baby work its magic.
Now I am 100% convinced that JD's dyno is dead on. I am very pleased with the results!!!
I will post this SLP dyno sheet as soon as I can get it scanned.
Thanks again to JPR for everything, this is a kick *** car!
Ron
Old 08-25-2003, 10:56 AM
gomer's Avatar
Default Re: JPR S2 H/C Package **Part 2** SLP Dyno Results
Are you running an electric water pump on the car? If so.. is it one of Joe's?
Old 08-25-2003, 11:01 AM
jfm
jfm's Avatar
Way to go,congrats to JPR and you Ron.That is an impressive set up.
Joe really did his homework on this package and the R&D involved with it.
BTW-this is an automatic not a M6,kick *** numbers.
Old 08-25-2003, 11:02 AM
UnbelievabLS1's Avatar
Awesome numbers! But I gotta wonder, what are they going to look like after a convertor and rearend?
Old 08-25-2003, 11:05 AM
jfm
jfm's Avatar
I dont think a verter will lower the number at all,if anything,due to it being lighter and LOCKED it may add a few ponies.IMHO.
Old 08-25-2003, 11:09 AM
offaxis's Avatar
Thgat is one awsome combo!! Cant wait to see that out at the track
Good luck with it
Old 08-25-2003, 11:15 AM
Was the stock verter not locked on the dyno or something?
I still think it'll lose a few with a converter.
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Awesome. Congrats!
Old 08-25-2003, 11:34 AM
JF WS6's Avatar
With like a 3500-4K stall? No way, he'll be losing a few for sure. A couple guys have also noted a 27-30RWHP loss going to a 12 bolt with gears.
Old 08-25-2003, 12:05 PM
more carbon's Avatar
a 12 bolt takes 30hp to run,holly ****???!!!
Old 08-25-2003, 12:13 PM
JS
JS's Avatar
Congrats bro...
That about sums it up...
The only thing thats gonna hurt u is the converter choice and gear ratio that u said your run. (3.42/3600)
If u want to lay down a 10 Sec pass its gonna need a TCS 4200/4.10's with a 26in ET Drag.
But it'll still run 11.3 all day long with the smaller verter/gears....
Good luck....
Old 08-25-2003, 12:57 PM
mike m's Avatar
so if all of you guys are saying this car will loose lets say 20 rwhp then over 430 true hp through an automatic is awesome. great job Joe i cant wait to see what you come out with next
blk01ws6 congrats on th #'s and thanks for dynoing on an independant dyno to prove to us what kinda power you are making, lots of luck to yah. enjoy
Old 08-25-2003, 01:43 PM
Hardtop's Avatar
Very nice #'s. Congrats. JPR has really got a great combination together. An independant dyno was not necessary for me to believe the numbers.
Bruce
Old 08-25-2003, 01:50 PM
JTM
JTM's Avatar
Probaly will lose 10-15rwhp through a new convertor, and 20-30rwhp with a 12bolt.
Old 08-25-2003, 02:17 PM
Jorday's Avatar
I want to see track times from thing, once you get your new converter?
Later,
Jordan
Old 08-25-2003, 02:19 PM
Nickn20's Avatar
20-30 rwhp loss with a 12 bolt? lol It depends on some things I have seen personally a 3 rwhp loss going to a 12-bolt with 4.10s, but may the car got stronger from one dyno to the next since the motor was fairly new.
Old 08-25-2003, 02:23 PM
Restricted User
2001 Pewter WS6's Avatar
Nice numbers...
Old 08-25-2003, 03:57 PM
merlinsrealm's Avatar
OK....So based on what 2 or 3 different people on this post are saying is that JPR's Shop car with a light weight converter and going from 3.23 to 3.42 gears pulling 456 at the rear with the same exact head and cam package will pull close to 480 at the rear if we put his stock converter and 3.23 gears back into the car???? Hummmm.....Cant wait to see this package on an M6 car. What will the next round of excuses be then.
Oh and I dont remember Ron ever saying anything about running a 12 bolt in the car so why does that issue keep coming up?
Eric
Old 08-25-2003, 04:04 PM
JS
JS's Avatar
I lost 11RW going to a 12-bolt/4.10 over my 10-bolt 3.73's.
From what I understand Ron's car is only getting 3.42's and no 12-bolt.
IMO he wont lose to much doing that.
But it wont be the best gear for the setup.
With Joe's EWP and a loose verter it'll still put down over 440RWH...
Old 08-25-2003, 04:09 PM
gomer's Avatar
Does the car have one of the new electric water pumps on it now? I thought he was testing one of them? I am very interested in JPR's water pump.
