View Poll Results: How Much Power Are You Making @ The Wheels?(part two)
300-350
56
16.42%
350-400
48
14.08%
400-450
77
22.58%
450-500
46
13.49%
500-550
35
10.26%
550-600
20
5.87%
600-650
20
5.87%
650-700
8
2.35%
700-750
8
2.35%
750-800
5
1.47%
800++ Damn!!!!!!!!
18
5.28%
Voters: 341. You may not vote on this poll
Old 10-30-2008, 01:48 PM
  #101
extremetoy's Avatar
471hp 471tq 6.0l w/ a rear mt 76mm. @5lbs
stock 317 heads
mahle forged pistons -4cc
stock rods
stock ls2 crank
60lb injectors
222/222 .563/.563 comp cams
through an m6
in an 01 s-10
Old 11-02-2008, 07:19 AM
  #102
shawn_c992001's Avatar
I just got on a dyno, 425hp/446tq, and 415hp/451tq on a Dynojet dyno with only 4 psi, numbers with meth and 8 psi coming soon!!!
Old 11-02-2008, 08:57 PM
  #103
02 BLK WS6's Avatar
Stock Bottom end (even stock rod bolts)
Cam only TSP 231/237
Built 4L60E PI Converter
2 Stages of N2O
1st stage HSW 125 dry off idle through the whole 1/4
2nd stage NX 100 wet on a 3k-6.1k window switch
best 60' 1.52 spinning
1/8 - 6.79 @ 102
1/4 - 10.62 @ 128
I go through the traps with the 2nd stage off.
