G5X3+FAST 2007 C6 +94rwhp/+51rwtq
Congrats on some killer numbers using the g5x3 cam from LG Motorsports.
I was wondering though, did they (LGM) tell you about the g5x3 vII ???
g5x3 vII is a touch more aggressive then version I and makes more power everywhere. I bet you'd have made another 10-12 rwhp and 10+ rwtq. My car was a test mule for the cam, and the numbers are in my sig.
Again congrats on the huge CAM ONLY numbers. GLM really can tune !!!
I actually got it from Howard at Redline Motorsports as he is a good friend. I had contacted Louis but he is so hard to get in touch with I just did the normal X3. If I hear back from Louis, I am up for pulling the current headers and throwing on a set of LG's to see if I can't pick up a little more torque.... Oh Louis........
Originally Posted by allngn_c5
Did you consider running a Meziere EWP for a few more ponies and better gas mileage ??
1 Post
Thanks for the comments bro. I was just suggesting it because on long highway trips I would routinely see 34 mpg (actual)..... Lots of time in cruise mode at 80 or less in 6th. Just sips the gas, and considering fuel prices etc etc. I also liked how the car seemed to pull harder in 4th and 5th due to the reduction in load on the motor.
Again congrats on your setup. She's a real screamer.
it looked like the cam was still carrying power when you aborted the pull, any reason you didn't ride it out farther? also, given GLM's tuning abilities, do you have plans of installing a larger cam? i'd like to see a 240/244 on a 112+0 or something. it's not like the driveability would suffer.
That car must pull like a freight train. Those are some impressive numbers.
Before I have him pull this cam out for a bigger one, I'd do some heads at the same time. Depending if the new weind intake comes out before the car is a collectors model will determine which way I go.
For this being a street car/setup it was never tuned on the dyno... It was a full street tune and then just had two pulls to see what numbers it threw up. I know the power will continue on a few more hundred RPM's but didn't feel it was necessary to spin it that high on the dyno. The car is shifted around 6700 on the street.
