anyone blow a engine during dyno tune
Well being tuned on the dyno is no different. They strap it down, and slowly and carefully while monitoring your air fuel mixture take it up to where they feel is safe.
IMO most times when something like that happens on a dyno, its from either a terribly built engine, uneducated tuners or in this game, you gotta pay to play... sometimes big power is an unstable creature and things can and do go wrong.
Either way, I would say a dyno tune is your safest and best alternative if youre thinking of getting your car tuned or doing any mods to it.
You run enough cars, tune enough cars, some are gonna break. I've seen broken pushrods, spun bearings, etc.
I've also seen people break connecting rods in half on the street. You build a high performance car, with the intent to beat the **** out of it, you're gonna break something eventually.
If it where only a matter of spending a ton of $$$ to assure you wouldnt blow up, the NASCAR boys would never have an engine failure. Right???
Last edited by scotthd; Aug 27, 2008 at 11:55 PM. Reason: did not think that was appropriate in hind site both have great ino
The dyno is no different than running the car wide open on the street or track. If there is a weak point in the setup, you will find it. I've seen driveshafts come apart (one nearly through the floorboards and caused me to need a change of underwear), clutches go up in smoke, and trannies go. But that is a very small number compared to the hundreds of cars I've tuned. When you start modifying engines/cars, anything can happen from the added stress and strain - but, if everything is well put together, it should be fine.
A good tuner will start off from idle and slowly work up the RPM range bringing the AFR in line before ever making WOT power pulls. If done correctly, dyno tuning is much safer than throwing a canned tune in the car and letting it rip...
1st pull, then started smoking-i had put about 2k miles on it-i suspect the guy running the dyno bumped my retard switch and it wasnt on, tore the ring lands out of the pistons-i knew this motor was living on the edge anyway, so i wasnt to upset over it, lol
