ported 92mm results
Old Sep 21, 2008 | 08:21 PM
  #41
TLewis4095's Avatar
Originally Posted by I RaCE In HeeLs
nice gain!! I wanted to get my dude a FAST 92/92 but he wanted to wait. bigger motor in progress
Then get a FAST 92 & port it to 95 for the bigger motor.
Old Sep 30, 2008 | 02:06 PM
  #42
Spectre86's Avatar
Originally Posted by WhySo6ick!
I thought I would share my Vengence ported 92mm intake results.A little history on the car and all pulls on the same dyno (dynojet)
2001 TA M6 completely stock 288hp and 319tq at 98deg
Next 12 bolt with 4:11's ud pulley,lid,xs 1 3/4 headers,ory pipe, hooker catback,spec stage 3 clutch,same LS6 intake and throttle body,17x11 ZR1's with 315 BF drags,comp cams 238/242-601/610@113.5+0 and patriot golds.with a tune it made:395hp and 356tq at 93deg
Yesterday with the 92/92 (ported by Vengence) setup as the only change it made 428hp and 379tq at 88deg all #'s sae.I have a set of there TFK LS6 heads going on in the very near future,so I'll keep everybody up to speed!These results are with no additional tuning.
I would like to thank Tracy at Revxtreme as he was very polite and very helpful! I will be back!
very nice numbers congrats
Old Oct 1, 2008 | 07:39 AM
  #43
Jim'sZ28's Avatar
sorry I could'nt get the over lay of the graphs.the heads are going on this week and I will make sure to show those.
Old Oct 1, 2008 | 08:08 AM
  #44
JL ws-6's Avatar
Race your car!
Originally Posted by Abdullah
you would gain another 15-17 rwhp with an SLP 85mm MAF and a 85mm lid with tunning.
You're living in a dreamworld if you think that's actually gonna happen in every case. 99.999% of the people I know that go and put one of those slp 85mm maf's on have nothing but problems, and I don't believe for a minute that there's 17 rwhp to be gained by getting away from a standard slp lid.
You go SD and ditch the maf all together, and the entire airlid for that matter yes there's that' kind of power there in SOME cases, but that's not even a guarintee.
FWIW, I've been 9.55 @ 142 mph with a stock, untouched maf, screen still in it an all, with just a 90mm NW tb and a 90mm fast intake, with zero porting done to it.
Old Oct 1, 2008 | 08:41 AM
  #45
Abdullah's Avatar
that what i found with some poeple gaining from 85mm lid/85mm MAF :
https://ls1tech.com/forums/showthrea...896&highlight=
maybe the poeple you talked about them didn't tune the PCM for the 85mm MAF and 85mm lid. what i know that SLP 85mm MAF doesn't need a new MAF table just a retune where the GM 85mm MAF needs a corresponding MAF table and a retune of course.
Old Oct 1, 2008 | 09:25 AM
  #46
JL ws-6's Avatar
Race your car!
GUys @ my shop have tested all that stuff with and without tuning, if there was another 17 rwhp that I could have gained by doign any of it, believe me I would have years ago.
If you see 5 hp, it's a miracle, or the weather that day is a good bit better.
Trust me when I say, that it's less then 1/2 the gain people claim, making the cost per HP really out of whack in the worth while department.
Old Oct 1, 2008 | 09:48 AM
  #47
ScreaminRedZ's Avatar
registered user
I agree that these items get very mixed reviews depending on where you look and who you talk to (much like and EWP). That being said, even if the gain is only 5 hp, I think it's worth it since the MAF sensors are under $200. Alot of people spend way more for less.
Old Oct 1, 2008 | 03:46 PM
  #48
firefighter813x's Avatar
Chris1313 claims his 85mm set up really helped to achieve 420whp (+/- a few) for his cam only 230/230. On another note, my cam only MTI X1 made similar numbers to the original poster @ 395/366. Does anyone really think these results could be duplicated in my, or other similar setups with the ported FAST? We're talking full bolt on stock heads, cam only cars...
Old Oct 1, 2008 | 05:40 PM
  #49
JL ws-6's Avatar
Race your car!
I highly doubt that I would see that type of gain with my 13.5 to 1 compression 402 race motor.... I have a stock fast 90 on the car with a NW 90mm tb.
If someone actually thinks that a ported fast 92 mm with the bigger maf and lid would help, man up and send me one and we'll do a dyno comparison, I'll make a pull with the car log the timing and a/f and all that, then do the same (adjust a/f to the same) and see what it does...
Every time I offer this, I hear nothing but crickets, because noone wants it to get out that it really doesn't make 1/2 the difference that they want you to believe.
Hell I'll track test it too to prove the point, that I bet the DA will have a larger impact then the intake tract will
Old Oct 1, 2008 | 06:48 PM
  #50
AINT SKEERED's Avatar
i gained 2 hp with the 85 mm maf
tuned with both and tested back to back on the same day while strapped on Futrals dyno.
My stock maf was bad and the 85 was cheaper then a stock replacement so it was not a bad deal.
Old Oct 1, 2008 | 07:12 PM
  #51
Detoxx03's Avatar
Dammit you gained 1rwhp more than me. I switched from ls6 to fast 92 and gained 32rwhp and 20rwtq. Enjoy it man
Old Oct 1, 2008 | 08:17 PM
  #52
That isn't a typical result though, is it?
Old Oct 1, 2008 | 11:29 PM
  #53
Detoxx03's Avatar
I have seen a few make gains around this amout
Old Oct 2, 2008 | 06:39 AM
  #54
ws6on19s's Avatar
Man I'm still sporting an ls6 intake, time to start saving for heads and intake, also I agree with JL an 85mm maf sucks, minimal gains and pain to tune, if anything go SD
Old Oct 2, 2008 | 06:45 AM
  #55
JL ws-6's Avatar
Race your car!
Yup, if you're at the point that the stock MAF is a restriction, then you need to do SD with the car and be done with it.
I can tell ya this, 9.5 @ 142 and it's still not a restriction, so how guys that are making 420 ish rwhp are worried about the maf I'll never understand.
Old Oct 2, 2008 | 08:00 AM
  #56
have you ever tried yours in speed Density ? Just curious if it was much of a difference at your power level or are you just stating that because you ran 142 mph?
I plan on running sd on my Nova with a built high compression 347
Old Oct 2, 2008 | 08:49 AM
  #57
BADSZ28's Avatar
Numerous tuners will tell you keep the stocker till you max it out or just go SD. I have gone SD. I love it. Car feels better all around and I have no MAF to restrict flow. The 85mm MAF upgrade is more to open up flow vs. a better unit than stock. That is why people will just go SD and so the MAF does not scew their tune.
Old Oct 2, 2008 | 09:11 AM
  #58
PewterScreaminMach's Avatar
The thing is, Jay, you can't just state, "My car runs this ET at this MPH, therefore the 85mm MAF would not help me at all" because you just don't know if it will pick up more. You don't THINK it will, but until you've run both of them, it's still just speculating that you wouldn't pick up anything significant, just like the other poster was speculating that the OP would pick up 15-17rwhp - not that I necessarily believe that, but you're both just bench racing/dynoing the cars until you actually make the swap and see real world results.
I personally would love to see you throw an 85mm MAF on the car just to see if it picks up anything significant. Like Ron said, it's just one of those parts where some people claim big gains with the swap and others claim little to no gains with the swap. You can always swap back to the stocker if you're not happy with it and sell it pretty much new for just about what you paid for it. But I wouldn't just dismiss an opportunity for possible horsepower just based on what other people are telling you when the general consensus is mixed, and especially when it's less than a $200 part.
I guess it just shocks me that you won't give a $195 part a shot when you'll tear every other little thing out of your car to save 5 pounds here and 6 pounds there. Even if you picked up just 5rwhp, that's like another 50 pound weight reduction! I would have thought you'd be ALL OVER that!
Old Oct 2, 2008 | 09:45 AM
  #59
JL ws-6's Avatar
Race your car!
Someone wants to send me a whole setup to test, I wll, but after seeing so many people put them on and see nothing, more tuning problems, the maf's not work right and screw other stuff up ( make the motor go pig rich when they go bad, or mad lean) no thanks.
I'll take the maf out before I ever try another one.
You think that if there was another 20 rwhp to get from swapping that stuff that was a 100% guarinteed gain that I wouldn't have don eit with all the $ that I have spent Joe? Come on man, get with the program LOL, I drop 10 grand a year in this car, if there was any bolton stuff left that was gonna give me another 20 rwhp I'd have done it a long time ago.
Old Oct 2, 2008 | 10:56 AM
  #60
I'm just saying I'd be curious to see if your car picks up anything; even 5rwhp would be worth it for $195. I can understand your argument about them going bad and screwing stuff up, though; that makes sense. I just figured for less than $200 you would have at least given it a shot. Like you said, you spend $10,000 a year on the car, so what's $195 that you can get back if you're not happy with it anyways?
But again, I understand the going bad and hurting the car bit. If that's your reasoning, I guess I can't argue that one. I just think that if your only reason is "It most likely won't pick anything up", that's a bad reason to not give it a shot.
Read this post, especially the first response which is from Patrick G, who I think we can agree knows a thing or two about these engines and states are typical results from what he's seen: https://ls1tech.com/forums/showthrea...ghlight=85+maf
