Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
camaro vs dumdumdumdumdum
Old 10-29-2008 | 08:56 PM
silverz28camaro's Avatar
Originally Posted by JTelesone
your 11.5 will kill him from a dig even on the street probably. but be carefull of racing him on slicks and you on street tires. what tires did you run the 11.5s in? I would come with those on. I have seen several evos here in the area that are HEAVILY modified as far as drivetrain, trans, fuel cell, etc with the gt35r and the are high 10 sec cars on hight boost and race gas. 400ish wheel is dead on for that turbo, but closer to a max than standard. be carefull from a 50 roll, if he knows how to brake boost the car it will run around the equivalent of a 400-425ish whp full interior fbody.
he PROBABLY will not be on race gas, and @ 15lbs PROBABLY does not have the supporting mods to maximize that turbo. Hes probably closer to the 340-350 wheel tops, if your making a solid 375wheel and matching or more torque you will get the jump and have enough to hold him off.
I had the 245-50-16 nittos on the 1.599 60' run.
My dynoed 373rwhp, and that was before i did the sux2bu ram air mod.
And seriously 130 traps speeds???? from JUST a tubo upgrade. Even I would drive one of those if that were the case... c'mon man... thats 30+ mph from a turbo upgrade, not gonna happen
*if you really wanna win through a little juice on it for good measure*
Old 10-29-2008 | 09:26 PM
Steiner's Avatar
I think you guys are confusing a 35R turbo with something else. On a sartee4 you'll get 400whp with just a 50 trim on stock internals. With a 35r you can expect 500whp if you run a bottleneck. Those turbos can hold 30psi+ and flow 64-65 lbs/min! That's pretty ridiculous. On a sartee4 with a built engine that turbo is good for major power THROUGH 8k RPM's but with stock internals it's not a good idea to push anything past 20psi. I'd personally never run a 35r unless I had the complete setup to support it. Running a 35r at 15psi is silly considering how long it takes that turbo to spool. All the power of 20G with the spool of a big turbo. What's the point? Sounds like the sartee4 owner is either in the middle of a build or just got some bad advice.
Old 10-29-2008 | 09:36 PM
Yes he is in the middle of the build and said he is breakin in the motor now so saturday it is a go. I think i should strap on the drag radials if the 35r is a potent as you claim.
Old 10-29-2008 | 09:43 PM
His redline is set to 7200
Old 10-29-2008 | 09:49 PM
TonyGXP's Avatar
friend has that turbo on his ACR. fully built bottom end and car has gone mid 11's at 125+. having said that, the car was just at the rental at atco the other day and like has happened in the past, his car did not run properly, the gasket on the turbo was leaking because a bolt broke.. i rode in the car and at 20psi in third gear it breaks the tires loose. if he's on the MT's i would definately be on mine. who knows? maybe he's a BS'er or has problems every other time the car runs like my friend's, just hope he's not the real deal because, i believe the higher the mph's go the harder it will be to hold him off (if he's legit.) as for 30psi on pump gas? he'd be insane. my friend thrw the C16 in at the track and turned it up to 30, on the street he can run 20psi.. from a dig, i don't think he has a chance in hell to catch you though, in the 1/4. like the other poster said make sure you and he knows where the race ends ahead of time.
my prediction; from a dig you by a car or 2 and from a 50roll he'll take you over 90-100... good luck, be safe..
edit* btw this dumdumdumdumdum has put down over 400 to the tire on TuneTime's Mustang Dyno..... before he got the bigger turbo. i **** you not (i can't stand them personally)
Old 10-29-2008 | 10:14 PM
Ok, thanks for the info and i guess we will find out. If he does beat me then i will congratulate him, but i will be back for revenge. my car was stock until i got beat by a full bolt-on mustang 06' and every since then i couldn't stop, so if i do get beat then it will just be more motivation.
Next mods will be 85 mm lid,maf,fast 90/90 or the new weiand,lower the car 1 inch with dragshocks, and shed another 60lbs or so. All things that will help top end.
Old 10-29-2008 | 10:19 PM
TonyGXP's Avatar
just throw a 100 shot on there, pull a couple degrees and spray his ***, he's got a power adder and so will you lol.. we installed my zex kit in about 2 hours, maybe less and it dropped me from 12.6 to 11.8.. in a brick, in your car it'll probably knock you into the 10's and add another 8-9mph
Old 10-29-2008 | 10:40 PM
What tranny do you have in that brick? I have been thinking about nitrous for the longest time, but i told myself to hit 10.99 on motor first with a dialed suspension.
If i were to add the nitrous i would want a progressive controller(because i love my 4l60e) and a window switch to cut power on shifts(again for the 4l60e) and i would want to install it to where no one could see or find it, whitch is what i am looking into for next year.
Old 10-29-2008 | 10:46 PM
nitr0racing21's Avatar
dumdumdumdum
why cant u right that
Old 10-29-2008 | 10:58 PM
TonyGXP's Avatar
stock 4l70e with billet servos and deep pan... i sprayed through the shifts and used the WOT switch, works perfectly... if you're going to spray it alot, often rather, i would do the window switch otherwise i don't think you'll need it with a built trans.. it's no different then having more power from any other combo you know? Progressive? not a small shot like 100-125 IMO at least, waist of money, hell i don't even have a purge kit. i just floor it armed with the ign off and it's purged, no "ricer" scenes, no drama..
btw i think that's hilarious that you can't right "S.RT-4" i had to add the period or it would look...like.. this!! dumdumdumdumdum
Old 10-30-2008 | 01:02 AM
PowerShift408's Avatar
Considering that you cannot do anything to take the stock computer of those cars to lift the rev limiter w/o an AEM EMS or SCT tuner, he has some money in this car (Those tuners cost $2k and $1k, respectively). I wouldn't believe him on the 15 psi either. That car makes at least 400 whp, unless he really runs it at 15 psi. For all you know, he could show up with a tank of race gas running 30 psi. Be ready for a fight, this shouldn't be an easy race for you unless the car is poorly put together.
Old 10-30-2008 | 01:10 AM
  #32
foreverzero's Avatar
OP what mods do you have?
Old 10-30-2008 | 08:47 AM
  #33
ls1charged's Avatar
that run was with No meth, Stock motor, stock head,stock cams @ 25psi but did have slicks on when he made that pass
Old 10-30-2008 | 08:49 AM
  #34
ls1charged's Avatar
this is the leading site for those guys and some of the turbo upgrades they sell and each turbo they tell u what u should expect to make
http://www.agpturbo.com/product.php?...cat=275&page=1
Old 10-30-2008 | 09:54 AM
  #35
gectek's Avatar
there is too much rice in this thread...all the ricer math and teh bench racing...there is an old saying"if IFs and BUTS were candy and nuts we would all have a merry christmas"
well just go out there and show him the merry christmas already.
make sure to post the vid
Old 10-30-2008 | 11:00 AM
  #36
Sammyboy's Avatar
dumdumdumdum................did it work?
Old 10-30-2008 | 11:21 AM
  #37
dsmfan95's Avatar
Originally Posted by Quick Sh0t xMLx
Most 4 bangers of similar displacement usually put down low 400 whp(on 93) with that turbo. His car is a bit lighter than yours as well. I think it'll be a pretty close race. Unless he rolls out with slicks you definitely got him from a dig but from a roll it could be interesting.
Know someone with an Evo 8, GT35r some big cams made 327 awhp @ 18 pounds.
Got another friend with a KA-T(S13) setup GT35, some BC cams he's also aiming for around 420ish rwhp.
The more I think about it the more I think you have no chance from a roll if he's legit. Good luck.
Who's your friend with the Evo8?
Old 10-30-2008 | 02:26 PM
  #38
AgentLS1Z's Avatar
This race is going to be pointless. You already beat him in looks. Okay beauty is in the eye of the beholder but you'd have to be blind to like those things. The only thing they have is power, and its still a Dodge.
Old 10-30-2008 | 02:33 PM
  #39
gectek's Avatar
The edit button is your friend!
Originally Posted by AgentLS1Z
This race is going to be pointless. You already beat him in looks. Okay beauty is in the eye of the beERholder but you'd have to be blind to like those things, or Takeru Kobayashi. The only thing they have is IMPORT INFLUENCE, and its still a(n) IMPORT.
fixed it
Old 10-30-2008 | 09:40 PM
  #40
donkey mule's Avatar
dumdumdumdum for the loss if you put some drag radials on and race him from a dig.
Quick Reply: camaro vs dumdumdumdumdum
