*415ci Dyno Predictions*
As the completion of my motor gets ever so close what kind of power do you guys think it will put out??? I will be running a medium shot of nitrous on this motor but im interested in the n/a potential. Thanks in advance![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
ShortBlock
Lq4 6.0L iron block bored and honed to 4.065
Diamond Flat top pistons -5.5cc/ Total Seal AP rings/Trends 2.200 wrist pin
Eagle 6.125 rods w/ARP 2000 rod bolts
Eagle 4.00" stroke crankshaft
Clevite rod and main bearings
ARP Main Studs/Side Bolts Kit
ARP Head Stud Kit
Fel-Pro MLS 4.100 bore .053”thick
Meziere Electric Water Pump and MotoRad thermostat
Ported LS6 oil pump
Valvetrain
Comp Cams Hi-Tech Roller Adjustable Timing Chain Adjustable
LS2 Timing chain
Comp XE R lobes, 244/248 .612/.615 @ .50 112+2 cam
Comp Cam hardened pushrods
Comp lifters
Heads
All-Pro Cylinder Heads (Ported)
Ferrea 2.08 (f6236) Intake, 1.60 (f6234) Exhaust Valves
Comp Cams Dual Valve Springs/Ti Retainers
Harland Sharp 1.7 Rockers
Induction
Port Matched Ls6 intake manifold
Hand ported Breathless Performance TB
Return style fuel system
Manual fuel pressure regulator
Delphi 42lb injectors
Breathless high volume fuel pump
Breathless Performance Intake system
Exhaust
Breathless Performance Step Headers 1&3/4-1&7/8
SLP Loudmouth exhaust
Drivetrain
Rockland Standard MN12 Bullet proof T56 with Carbon Fiber Synchronizer Rings,
Steel 3-4 shift fork,
Z06 ratios-2.97,2.07, 1.43, 1.00, .84, .56
Rockland standard 3.90 gears
Rockland standard unbreakable axel shafts
Hardened output shaft
Ram Powergrip HD clutch/Billet flywheel
B&M ripper shifter
Compression Info
Bore 4.065
ST = Stroke 4
RL = Rod Length 6.125
Number of cylinders 8
Deck Height (how much pistons come out of the hole) 0.013
Piston Dome or Dish (- for a dome + for a dish) -5.5
Compressed Head gasket thickness 0.053
Cylinder Head Chamber Volume 62
Static Compression Ratio 13.06 :1
Dynamic Compresion Ratio 9.39 :1
Rod to Stroke Ratio 1.53 :1
Bore to Stroke Ratio 1.02 :1
ShortBlock
ARP Head Stud Kit
Ported LS6 oil pump
Valvetrain
LS2 Timing chain
Comp lifters
Heads
Induction
Exhaust
Drivetrain
B&M ripper shifter
Compression Info
Bore 4.065
ST = Stroke 4
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Sounds like one bad azz combo. I am not familiar w/those heads, but if they are up to the job, I'm guessing over 600rwhp. With that much compression, is there a reason you didn't use one of those Pat G LSL lobes? Those cams seem so hot right now.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
LS1 Tech Administrator
Please post in the dyno section after you have results.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I made 540/495rw with that cam on a 114, a point less compression and 90/90 with TFS 235's. I would guess you could get 550/510rw with the extra compression but your intake is going to kill you. Your headers are too small as well. I think the SLP will hurt also. Big cube motors need straight 3" all the way out. Realistic numbers for your current combo with the gears is probably 525/500rw. Good luck with it. I went with one of those new fandangled Pat G cams and I am making 575/530rw now. I never did the EWP or 3" exhaust.
p.s. With your DCR being so high you will proabably only be able to get about 22* of timing in there on pump. I am assuming this is going to be a race gas motor. If so I would bump the cam way up and have at it.
Thanks for the replies guys....i was really hoping you were going to shed some light Pray as your combo is pretty similar...i would go open header but its just too loud inside the car, maybe strictly for dyno numbers ill take the slp off. This will be a race gas or pump/race gas mix motor as i dont think the 91octane available will cut it. The only reason im running the ls6 intake is to make the fast fan boys mad hahaha...if im not happy with the hp results i will switch over to a vic jr carb setup i think a fast is just splitting hairs when running a power adder.
