11 Sec Material???
My mods are in the sig. i was just curious if anyone thinks i can dip into the 11's with the numbers i put down and my setup. My only concern is my rearend but i think i can cut some 2 sec 60fts easing out of the hole (which Blows
) What do ya'll think??
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Depending on elevation .Buddy with similar power runs high 11s at like 1600 feet altitude. If your track is similar or lower you should easily be doing the same.If you don't have nittos or drag radials then you might not get 11s. I would think you should be able to do a 1.8 or 1.6 60ft on tires like et street radials. Nittos usually not quite as good as the et street radials. I have run both on my 96z. NIttos are great for street and some track but et street radials rule the strip.
Pure street tires you might be really mad. My 97ta got slower with 4.10 gears on street tires.Spin or bog city..
