Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
500 whp head and cam ls2
Old 02-16-2010 | 11:09 AM
slowc6's Avatar
Default 500 whp head and cam ls2
Hi will texas speed L92 head and cam package with there 231/236, .641"/.615", 112 LSA camshaft. And a fast lsxr 102 get me at the 500whp mark.
I have a 05 C6 6speed with kooks 1 7/8 headers z06 3inch xpipe and z06 corsa axle back with callaway intake . I like the price of there kit and I hope it will.
http://www.texas-speed.com/shop/item...d=831&catid=47
Old 02-16-2010 | 12:15 PM
Slowhawk's Avatar
LS1Tech Sponsor
I would expect 460-480rwhp from it.
Old 02-16-2010 | 12:24 PM
Shawn @ VA Speed's Avatar
we hit 505 with an l92 headed ls2,but the parts we used were much different.I would vote for 480 as well
Old 02-16-2010 | 01:07 PM
slowc6's Avatar
what could i do to get an extra 20-30whp on that set up bigger cam or maybe a 102tb?
Old 02-16-2010 | 01:31 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Here's a similar combo we did that made 500rwhp, but it was the LS3 short-block (more bore size = more flow and compression as compared to the LS2).
https://ls1tech.com/forums/dynamomet...-000-mods.html
I'd guess closer to 480ish as well with the LS2 short-block!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-16-2010 | 02:10 PM
Slowhawk's Avatar
LS1Tech Sponsor
If drivability is not an issue with high rpm power(lack of low end power) then you can go with a bigger Cam(cut the pistons) and rev the **** out of it.
Also the 05's are not very fun to tune in.
Old 02-16-2010 | 03:10 PM
More cam = Flycutting pistons too
__________________
Old 02-16-2010 | 05:45 PM
maxspeed96ct's Avatar
Just do heads, cam, fast 102 and a pulley and the car will be a beast.
Btw That texas speed kit is a awsome price but that cam is alittle on the BIG side for driveablity.
Old 02-16-2010 | 05:54 PM
That cam has one or two degrees more overlap than the cam in your CTS-V....not too big by any means, and the street manners are actually really good with it after a good tune!
__________________
Old 02-16-2010 | 06:13 PM
Ill take your word for it since it is your kit
Old 02-16-2010 | 06:38 PM
Slowhawk's Avatar
LS1Tech Sponsor
Or just do a blower and make 550-600rwhp.
The Cam is alittle bigger but the heads affect the drivability and power.I'm sure it's fine but to get the most you would want compression to be raised a bit which will require cutting the pistons. This is to get to the 500rwhp mark.
Old 02-18-2010 | 10:47 AM
cowboyup's Avatar
I wish there was something more I could do besides changing out the heads or cam to achieve the 500 mark.. almost there..
Old 02-18-2010 | 03:53 PM
slowc6's Avatar
Try Meziere LS1/LS2 Electric Water Pump should get you there
Old 02-18-2010 | 04:53 PM
BES Stroked Nova's Avatar
i got a iron 6.0L setup with L92's and a 24x cam. Carb/efi intake...
anyways, it makes over 500whp. drives pretty well on the street.
BUT it LOVES RPM's. I shift it 7800.
So yeah, it can be done. but just not easy.
Old 02-18-2010 | 05:19 PM
1blownss's Avatar
I was kind of surprised when I saw all of these guy's saying that it would be difficult to make over 500 hp with a head and cam package ....Go to LG Motorsports website or even lingenfelters websites and you will see plenty of 05-07 C6's that are making in excess of 500 hp with a
Head(L92's) & cam (G6X3) L76 Intake and headers .... I have seen a few of these and actually drove a few of these vettes and they are wicked ...Hope this info helps
Here is a link to look at
http://lgmotorsports.com/gallery/dis...album=3&pos=39
Old 02-18-2010 | 05:26 PM
I never said it was hard,just that we used different parts that what the OP was looking to use.
Old 02-18-2010 | 06:30 PM
1blownss's Avatar
No disrespect to you shawn...you guy's are at the top of the foodchain for making power and building fantastic motors .....I just saw all the post and thought Wow , this is not difficult at all if you are stating out with 400+hp at the crank with a LS2 motor ...I would say that 550 crank HP is definitely doable with the L92 Heads and the L76 intake along with the correct cam and headers he will be good to go...
Old 02-18-2010 | 06:33 PM
well if you want to talk crank HP, my 6.0L made 598hp at 7500. and It dont fall below 550 from 6200 till 8000.
Old 02-18-2010 | 10:38 PM
hivoltagedriver's Avatar
My cam-only set up made 480rwhp on SNL's dyno. They are in the middle of putting together a kit for guaranteed 500+rwhp on an LS2. One of the guys there made 500+ through cats with their cam and PRC 227 heads. It is possible. The cam I'm running is a little bigger than the one listed, and the car is my DD. It make great power, and is a breeze to drive, but I had a good tuner too. One thing to watch out for with the L92 heads and a big cam is the need for fly-cutting the pistons. Stick with a set of CNC'd 243's or aftermarket heads, and a healthy cam, and you will reach your goal.
Old 02-18-2010 | 11:08 PM
1blownss's Avatar
I think that you are better off going with a local shop that has a reputation like a VS or TS or Ling etc. These guy's will get you where you want to be and your goal is very doable on the $4000.00 to $4500.00 budget .....
Make sure you go with someone that has been around a while and has a good following of customers that speak very highly of the speed shop .....
Good luck !
Quick Reply: 500 whp head and cam ls2
