Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
Ported 243 and 228r cam?how much hp?
Old 01-11-2011 | 05:04 PM
bmf5150's Avatar
Default Ported 243 and 228r cam?how much hp?
How much horse power do u think a stage 2 Texas speed 243 heads with there 228r cam and ls6 intake??how much at crank and how much rear wheel would ya guestimate?
Old 01-11-2011 | 05:57 PM
JPH's Avatar
JPH
400rwhp and 380rwtq roughly
Old 01-11-2011 | 10:12 PM
usafws6's Avatar
i made 410 and 389 rwhp/tq with that cam. small valve 709 heads, fast intake and tb, and the usual boltons, through a catback. m6 tranny and a shortblock with over 100k miles
Old 01-11-2011 | 10:14 PM
usafws6's Avatar
im assuming you want numbers for a stock ls1 also. so id say around what i made, you stand to make more with the FAST setup. depending on the tuner and dyno also. but let me ask this, why the 228r, its an ok cam, but a bit small. why not an ms3, those heads will keep flowing after the 228r quits.
Old 07-09-2011 | 11:22 PM
bmf5150's Avatar
What size throttle body and mass air Should be used with this combo???
Old 07-10-2011 | 12:09 AM
01ssreda4's Avatar
430 to the wheels in an M6.
Old 07-15-2011 | 12:22 AM
LSjim's Avatar
i put 400 rwhp with stock 799 heads 228r on a 112 professional products 96mm with a nickwilliams 95 throttle body through a a4
Old 07-15-2011 | 12:26 AM
180ls1's Avatar
agreed given the heads are milled some to bump the compression and all else is well with the car/tune.
Old 07-15-2011 | 01:05 AM
RedVertTA's Avatar
420+ Through M6 with those parts and all the bolt ons.
Old 07-17-2011 | 08:01 AM
KC&97TA's Avatar
I almost did TEA stage 2 243 heads and a 228R cam, researched both the FAST90/92 and LS6 intake, A4 numbers were around 400 to 425'ish rwhp, for a stock cube LS1.
Local guy has TFS 225's and a 228R cam his numbers were 440/430 if I remember right, LS6 intake.
I ended up going a diffrent route.
Old 07-23-2011 | 10:56 PM
02LS1ram's Avatar
I made 417hp/400tq when I had my 228r, stock head, and
Fast 90/90. With 243's u should be in the Mid to lower 400's atleast!. Ditch the ls6 and get a fast intake. U'll pick up 20 whp over the ls6.
Old 07-23-2011 | 11:06 PM
Theblacknightls1's Avatar
was about to say the same thing.. I made 432rwhp with my 228r cam i had in a t/a and it was with a ls6 intake
Quick Reply: Ported 243 and 228r cam?how much hp?
