track time guesses
track time guesses
thinking about possibly heading out to the track tomorrow. depends whether or not i have time to swap intake manifolds.
details:
'95 camaro
-lt1 (compeletely stock internals) stock heads, stock cam.
-built 4l60e
-homemade remote mount turbo running 7psi
-turbo is a Garrett tp38 w/ aftermarket .84 a/r exhaust housing
-intercooled
-Pacesetter headers, 3" ORY
-58mm throttle body and intake ported for 58mm tb
-mallory hyfire box
-3.42 gears
-stock corvette 2000 stall
suspension:
-homemade body mount torque am, panhard bar, upper panhard bar, lca relocation brackets, sfc's, 5 point cage
-bmr lca's
tires:
et street bias plys 26"
or if i get lazy or dont have time to swap wheels i'll just run my new 315/35/17 khumo v700's
car weighs 3,900lbs with me in it. my car's a fat pig. i know.
so what do you guys think it'll run? i've ran it many times before, just wondering what you guys will guess
temp tomorrow night should be ~60 degrees. track is 1,243 feet above sea level
details:
'95 camaro
-built 4l60e
-intercooled
-mallory hyfire box
-3.42 gears
suspension:
-bmr lca's
tires:
didn't end up taking it out. my brother took his m3 out so i just went with him. HE ended up over heating and didn't even get one run in. if i had gone we would've had two broken cars!
in the past:
i had some wastegate/exhaust leaks before when i ran my best time of 12.9@105 which was with:
3psi in 1st
7psi in 2nd
0psi in 3rd
once i got the boost/exhaust leak fixed and could hold a constant 7psi i ran:
first run (blew intake off)
15.00 @ 68.51 2.10 60'
second run
13.46 @ 113.34 2.53 60'
third run
13.50 @ 113.35 2.42 60'
fourth run
13.17 @ 113.40 2.16 60'
fifth run
13.00 @ 114.13 2.075 60'
sixth run
13.00 @ 113.93 2.097 60'
with the stock converter i cant launch it at all. if i had the right stall and could foot brake 2,500 rpms i'd be able to leave the line at 2-3psi and significantly cut down those shitty 60's
getting it dyno'ed april 2nd. i'll post up the graph afterwards
in the past:
3psi in 1st
7psi in 2nd
0psi in 3rd
second run
third run
fourth run
fifth run
sixth run
i was going to buy one, but i'm going to school right now and dont really have a job job. i just making money doing car work/fab on the side.
i figured i'll just wait til i graduate and i'm making money so i can buy a GOOD converter. and now just some cheap loose one.
