Ideas? Guesses? Thoughts on what I did wrong?
Just coming to an end of my build and going to get it onto a dyno for tuning and numbers when I get home from my latest military outing (still several months off). Just looking for ideas on what you all think it should run or hell, if I f'd up somewhere. Its a 1997 Z28 lt1 car running through an M6 with 4.10 gear on a 275-40R18 rear tire...
*Lt1 stock bottom end
*Comp Cams 07-467-8 cam
230/236 dur
576/570 lift
113 lsa
*GMPP Lt4 heads
ported intake/exhaust
310cfm flow rate
AFR 2.02” intake
AFR 1.60” exhaust
Comp Cams 1.6 roller rockers
Comp Cams roller lifters
Comp Cams beehive springs
*Edelbrock Performer Air Gap lt4 intake
Ported
*Arizona Speed and Marine 58mm throttle body
*Bosch 36# injectors
*Arizona Speed and Marine headers
*Magnaflow stainless steel catback
*Nitrous Outlet Wet Plate Kit w/100 shot
*Secondary Air injection delete
*EGR delete
*Downstream O2 sensor delete
*Catalytic converter delete
Guesses???
230/236 dur
576/570 lift
113 lsa
*GMPP Lt4 heads
310cfm flow rate
AFR 2.02” intake
AFR 1.60” exhaust
Ported
*EGR delete
Guesses???
