power/et guesstaments
my new forged bottom end combo is almost making noise so im curious what you guys think it will make for rwhp.
l33 block with 3.830 bore and 4.8 crank(301cu in), tick cam 111.5+4.5, .624/.630 lift, stock 243 heads, tooley springs, should be around 10 to 1 comp, csu blow through 750 on E85, meth inj with single nozzle after 10psi, 475/87/1.10 at 18psi(thinking of dropping that down to 15 but 15 is where the gate opens now)
if you mind guessing what the car might run, 3300lbs race weight, 3600 ptc 9.5 tc, t brake 400, 3.25 gears, tci 4 link, 275 dr's..
thanks guys..
my guess is 700rwhp and 9.40 at 142 ish..
thanks guys..
