3100lbs. 347C.I. N.A. FAST 102 CNC 243's 238/244
Now that I have most all of my info, I would like to get some guestimations . I have a 1990 Camaro that weighs in at 3100lbs. The drivetrain consists of a 4000 stall TH350 with a brake connected to a 9" W/4.56:1 heard. So far it hooks like a ****. I am installing a NA LS1 with the following specs. I have all the parts and should have the motor assembled and in the car next week. I am just looking for some similar experiences if they exist.
3.905 bore,6.125 rods and -2cc flat tops
60cc 243's C&C ported by Lloyd Elliott and .051" head gaskets (11:1 SC and 8.47 DC)
The heads flow 287-216@600, 282-209@550, 275-196@500
The cam is Pat G spec'd to 238/244 626" /626" on a 109LSA +2 adv.
FAST 102 unported intake and TB
1 3/4" open headers (I know, but the market is limited for third gen swap headers)
The old setup was the same for the car but a bone stock LS1 down to the intake. It went a 7.54 & 12.004 in decent weather. It dynoed 310 RWHP. The car will be tuned by Pat G once again for the combo so we all know it will be spot on. I am wanting to hear some predictions for HP and ET along with criticisms, good or bad. Although, like everyone including John Force I have a budget so don't be too mean. LOL I would really love to see the car make in the 500+ range and run down in the single digits which I know is awfully optimistic but I have a secret blue weapon if it doesn't work out.
![Lhdevil](https://ls1tech.com/forums/images/smilies2/lhdevil.gif)
Weight reduction will be the next order of business. I wanted to race it stock one more year and then go turbos but plans change and I had this motor already near built so here we go. Mid to low tens is what I expect but I am gonna shoot for a single didgit pass.
Very similar to my Thirdgen, but I've got a T56.
With the stock engine, I went 7.62@91.5 in the 1/8th. Unopened, bone stock 02 LS1 swap with the Hawk's headers and a tune.
Then, I did this:
https://ls1tech.com/forums/generatio...ls1-build.html
Managed an 11.26@122.8 banging the gears, at a 3450lb race weight, driver included.
No doubt if you're lighter and with the TH350 you'll be 10's right away.
Here's the "results" thread.
https://ls1tech.com/forums/dynamomet...whp-394tq.html
This winter I switched to Holley EFI and a Tick SNS 2 cam. The smaller cam is way better for street driving, I'm curious to go to the track and see how the ET and MPH change.
Then, I did this:
Thanks. Though your car is set up quite different, the motor is close to the same build. I was hoping to creep a little closer to the 500 RW mark but it is what it is. My 7.52 1/8th was with the LS1 intake. I could see it picking up a tenth or better with a better intake. I may try it before the new motor goes in because I have hit some obstacles with the new motor.
