368 Ci LS2 Dyno guess..?
Any Guesses what she'll Put Down?
Motor comes back from Machine shop this week!
Built 4l60e
3000 stall
3.90 gears - 10 Bolt
Bigs and Littles
LS2 Block
4.020 flat top pistons
Rings gapped for a 250 shot
LSA rods
LS3 Crank 24 tooth reluctor
Custom Grind Cam
235/242 .620 .615 112 lsa
706 heads
milled .020
Hand Ported
243 Valves
ls9 head gaskets
ARP head Bolts
Hand Ported ls2 Intake
Nic Williams 92mm tb
Built 4l60e
3000 stall
Bigs and Littles
LS2 Block
LSA rods
Custom Grind Cam
706 heads
milled .020
Hand Ported
243 Valves
ls9 head gaskets
ARP head Bolts
Your cam is essentially the same as mine if mine were hydraulic other than mine is 113 lsa.
Your heads likely flow a little less than mine.
I'm not super familar with the LS2 intake results once they are ported.
My car made 438rwhp but only ~380tq. I think yours will make more tq but the gain of the cubes might be offset by the heads and intake. If I'm underestimating them, then you could do better.
My heads are 799s milled .015" with a valve job and full hand port by a SAM student. They seem to work pretty well but not as well as the best CNC 243s or aftermarket. On proper size bore plate they should flow 295-300cfm intake.
My intake is a Fast 90mm that I ported the wedge out of and tried to smooth rough spots.
EDIT: I also always forget I'm putting power through a heavy *** 3.5" steel driveshaft and a 12bolt too. So you very well could do better.
