Hi guys. It’s been a long time gathering up
parts for this build and now I’m just waiting on delivery of pistons for engine builder to start the build. Build is as follows: SHP LS Next Steel Block with 4.155 bore and 4 inch stroke and 1/2 inch Head Stud provision. Rotating assemble is Callies Compstar Crank, Diamond 2000 hp pistons and Lunati Pro Billet I-beam rods. Compression around 11.5 to 1. Rings are gapped for 350-400 shot through Nitrous Outlet Direct Port. Intake is Tony Mamo ported FAST with regular runners and 55llb injectors. Heads are Brodix 6 Bolt LS3 CNC Br Bp with stainless intake and Inconel exhaust valves. Cam spec’d by Martin Smallwood at 246/262 and .629/.612 at 115+4. Lifters are Morel 5206 link-bar. Pushrods are 3/8 and .105 wall. GM Performance 1.8 ratio Rockers with trunnion upgrade. MSD Coils providing the spark. Exhaust is 1 7/8 headers through twin 3 inch cut-outs off the headers. Power will be transferred to the wheels through a Performabuilt Black Edition 4l60e transmission (revised 1st and 2nd at 2.83 and 1.55 respectively), Pro Yank 3600 Nitrous Converter and Mark Williams 12 Bolt with Wavetrac, 3.73 gears, 35 spline and 5/8 studs.
What do you guys think of the build and what do you think she will make n/a?
Nitrous Outlet Direct Port with Plate as 2nd stage.
