What kind of power will it make??
Hey guys figured ask y'all what you think my set up could make?? My hand got split in half at work a few days ago so I'm just getting a little bored, so humor me
91 Camaro z28
Iron block forged 370
BTR Trinity intake
Holley Dominator ECU
Holley 120# injectors
Icon 102mm TB
Dual 340 pumps -8an/-6an PTFE feed/return lines
Dual feed to front of rails
Racetronix regulator
94 chevron(no ethanol) pump gas mixed to 105
Built 4l80e with Jake's lvl3 rebuild and recalibration kit
Circle D 258mm pro series single disc converter
VS racing billet 80mm T6 turbo
Vs racing 50mm wastegate with dome pressure sensor
7# gate spring with 8# of dome pressure
Dual Mac solenoid boost control
A2A 3" intercooler
MWC fab 9" 3.25 rear gear
275/40-17 Mickey Thompson Street et drag radials
So I did get the bugs worked out before I headed out to work and have been hitting 15-16 psi. I was doing runs and logging things as I went along. I'm also at 13 degrees timing at WOT.
Just curious what it could potentially make as is, I can't really do much as I'm a bit of a gibble right meow.
Thanks everybody
91 Camaro z28
BTR Trinity intake
Icon 102mm TB
A2A 3" intercooler
Thanks everybody
Which cam, which heads? These are what help determine horsepower besides the hairdryer, so?????
