LS6 Long Block in VA
The motor is a stock displacement LS6 with the following parts. All short block parts were new when motor was built in 2008.
Gm Crank
GM rods with ARP 2k rod bolts
Diamond racing forged pistons flat tops with -4 cc valve reliefs.
Cam is the NEW version MS4 specs are 239/242/ .649/.610 111.5LSA
LS7 lifters hardened TSP pushrods.
Roll maters timing set.
All gm gaskets
Heads were used with last motor and have about 8000 miles total on them. They were cleaned up with all new seal and such in late 08.
Heads are the patriot stage 5.3l. They were ported by TSP with titanium valves. New PRC 650 springs and Harlan sharp roller rockers installed last year.
You get the long block only… NO intake, headers, accessories… I will upload N/A street tune into buyer’s PCM and make small adjustments to tune... I.E. gears, DTC and timing for nitrous.
Looking for 4,000 O.B.O for more info call/text me at 325-864-1653..
let me know. thanks
