350 010 Block, crank, rods, 993 heads, headers
Everything for $100 Pick up only or I can meet you between DC to VA beach.
350 small block 010 high nickel content 2 bolt main. Its been coated in grease so it will need to be dipped and bored but otherwise perfect shape and includes stand.
Crank for 350. Also coated in grease and will need to be cleaned up but was checked out straight and polished at the same time. Also balancer and pulley.
350 rods stamped 1-8 and coated in grease.
993 heads found on 70s cars everything from passenger to Corvettes. I have some of the rockers, springs, and valves.
