So...what upgrades are everyone doing over the winter...2009 goals?
Race car will probably be staying in the trailer this summer... I want a bigger garage before I put any $$$$ into the race car. Maybe port the blower on the Cobra to hold me over for the season.
Just got the converter in ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Rebuild tranny
10 pt cage
Relocate battery to the trunk
K member/lower a-arms
manual rack
race brakes
front adjustable shocks
abs delete
1 7/8 headers
port vic jr
new tune
Goal is 9.50s N/A
Rebuild tranny
10 pt cage
manual rack
race brakes
abs delete
1 7/8 headers
port vic jr
new tune
Goal is 9.50s N/A
so far ive got a 9" full suspension and i hav the lt1 383 short block i just need to get it cleaned up and put that together then weld the cage in goals for a 9 second pass next year on a 200 shot
Vararam G8 intake is set to release end of Jan...gonna do that and american racing headers to custom corsa axle back or american racing headers to e-cutouts to the stock mufflers, any inputs?
plus formato ported intake and TB and a retune.
Asp crank pulley, Heads still not sure which to go with. Then fast 92 set up. A good tune.
After those I should be good for a while. Everything else is done.
Goals..
11.50 at 123 n/a... If I achieve this goal, I'll never go back to a ford again, I mean 123 mph in a 3600 pound car with a 346.. While maintaining full stretchability.
10.99 at 130 on 150 shot... Yes I know it should do better on a 150, but I'd be happy with a 10 anything.
Goals..
Race your car!
Collecting parts, that will either make it onto this car, or for another project ![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
Probably won't move the car an inch this year, it did everything I wanted it to do last year and I could go run 9.50 index with it just as it sits, set of valve springs and a new set of tires just for the sake of changing them and go... but I have a couple changes I'd like to make to the car first... unless it sells, in that case I have a line on a clean 98 v6 firebird hardtop manual everything car that I'll strip and build with the goals a little more clearly defined from the get go.
Either way doesn't matter to me at this point, I'm in no rush.
Have alot of stuff I wanna do around the house this summer and it's all time consuming big projects, some of which I'm not really looking foreward to.. Like digging up about 1/2 my back yard to put some drainage pipes in so the spring will run off rather then soaking my whole back yard like it does now.
Chances are, I'll be digging in the back yard for 1/2 the summer. Will be a good weight loss plan though
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
hmmm lets see... well im away at school most of the off season plus i dont have heat in my garage yet so i wont be doing this stuff until late spring early summer... but i got a few things i have started working on...
VFN Reg Sunoco Pin on Hood (already came in and is resting on top of the motor...)
A/C Delete (havent started)
EGR/AIR Delete (started but not finished)
Front bumper support delete (finished)
lightweight battery (havent purchused yet)
LCA's + relo brackets (not purchused yet)
SFC's (not purchused yet)
Goals for the end of 09 are:
3200lbs or lessraceweight
12.2x pass
1.65 or less 60ft
i think there is some other things im forgetting... since i have been home working on cars at sullivan tire i havent paid much attention to the LT1, im always sick and tired of wrenchin by the time i get home from 9 hours of tires, alignments, brakes, tie-rods, LOF's, etc... plus i got to do two rear quickstruts on my beater and give it a tune up... oh and pay for insurance on the beater for the year... so im pretty much moneyless until summer... plus working on a 14 year old car in a blistering cold cramp garage dosent sound too appealing to me at the moment...
im hoping to drive the car a bit more next summer, she was more of a track only car last year. and i hope to hit the track a good 5 or so times but i hope to drive the car more on the street and actually enjoy it...
12.2x pass
1.65 or less 60ft
#34
Just installed a set of 2-pt UMI SFC's, adjustable panhard bar and LCA's the other day. I have a PRO 5.0 shifter and some new tranny fluid ready to go in whenever it warms up a bit. other then that possibly a set of kooks or ARH when i get my taxes back. Also the car REALLY needs a new clutch master, but im not looking forward to putting it in.
#35
work sucks so bad right now and i raced so little last season do to lack of intrest, i might not even go back together this season. i say that now, come march april im sure my mind will change, but all i have to do put my motor back together. new rings bearings, im going to use all my other stuff. pistions, can etc etc etc. new timing chain and oil pump.
i traded my glide for a th400 and im going to get TEA 265 Trick flow 6 bolt heads.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#37
yeah its a true dual but...the factory set up is super restrictive manifolds, terrible 90* bend before the cats, then it goes into a 5 foot long muffler, splits goes into 2 bullet resonators, then into some of the most restrictive flowing stock muffler barrels ever. If you ever wondering why the G8's are so damn quiet. that plus the ****** DOD cam
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
