:Engine Noise- Video Inside:
*The noise is NOT accessory related. I pulled the belt again to verify and the noise still happened.
*I logged some data while cruising. There is "false" knock from me learning how to drive a Spec3 clutch that you cannot slip
*At frames 3025-3075 I rolled into the throttle only to find things not agreeing and making noise. It sounded like either a clutch disc falling apart or a 13mm socket hitting something
*I examined the engine bay again to see if I could see a socket- no such luck
*The noise appears to be coming from the middle of the engine, on top
Who knows at this point. I'm ready to drive the car off a cliff. The part that pisses me off is that the noise just appeared out of the blue. Things that changed from the time I didn't hear the noise until I heard the noise: slightly used Spec3 clutch/flywheel, new slave cylinder/TOB from Byunspeed, (1) lost 13mm shallow socket.
Thoughts?!?!?!?
I found my problem. It turns out that three (3) of my Harland Sharp rebuilt stock rockers were failing on me. The needle bearings were binding at times and probably causing the pushrod to bounce around a little. I got the car back together yesterday and the noise was gone. I will keep an eye on it for the next couple of weeks. The three bad rockers were replaced with used low mile stockers. I plan to purchase some Yella Terra non-adj or new stock rockers when I save up some money and replace them all.
https://ls1tech.com/forums/generatio...cs-inside.html
