Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Head and Cam installed on my 2010 Camaro......Track next
Old 05-16-2011, 01:24 PM
LS1Tech Sponsor
Slowhawk's Avatar
The vig's definitely have a sloppy feel but 60' pretty good. Yanks are alot tighter to drive around with.
Old 05-16-2011, 03:58 PM
LS1LT1's Avatar
Question
Originally Posted by scottywheels
I went 1.65 stock with The vig
Well, not stock, but with just bolt ons (stock internals) I think you mean?
Old 05-16-2011, 06:34 PM
edmanet's Avatar
Originally Posted by LS1LT1
And that may not help, that tire/gear combo might be good once the blower goes on but NA your gearing is going to be a little weak. The low first gear in the trans will hopefully make up for most of it though.
Everyone I know with a G8 that is NA with a A6 went slower
when they put 28" DRs on the rear. It lowered the effective gear ratio too much. It should be the same with a new Camaro. They share the same trans.
When my G8 had 435hp it ran 11.66 at 117.89 with the DA at -260.
Old 05-16-2011, 07:48 PM
Kenny H's Avatar
I don't doubt the Vig 3600 will get out of the hole. My issue with it was top-end. I really think the '02 I had was stronger stock from a 60 MPH then with the Vig 3600. The big Yank I had on my '98 Formula was definately wayyy more efficient on the highway.
Different animals though. I would think the 5th gen has more high RPM power and the A6 surely will help a lot.
Old 05-17-2011, 01:13 PM
scottywheels's Avatar
I wouldn't mind trying the circle d convertor they are supposed to be really efficient just to see if there is a change
Old 05-17-2011, 02:43 PM
DannoWS6's Avatar
My next converter is a Yank or circle D.
I had a TCI long ago which like the vig is a little loose. If those cars weigh almost 2 tons I can only imagine it being worse.
Let me put it this way I have a 4000 stall now and its way too tight for a track converter and has **** STR. It's all about the strator design. My old TCI 3500 was looser and also 60'ed better than this 4000, but its wasn't as efficient up top.
I'm leaning towards a yank ss4000 or a circle d5c 4000. There is more than stall speed to determine a good driving converter that can still make numbers at the track.
Old 05-18-2011, 04:30 PM
I actually dont mind it driving around. It is a little loosebut not to bad.I might try the Yank or Circle D to see
