Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Crazy heat wave over....
Old Jul 25, 2011 | 11:51 AM
C_Rules's Avatar
Default Crazy heat wave over....
This past weekend was ridiculous in the northeast. I drove my car throughout it though. Didnt overheat with the a/c on but was running pretty hot. Just curious to see what water temps you guys were seeing in your modded fbods this weekend a/c on or off.
Old Jul 25, 2011 | 12:01 PM
IDriveChevy's Avatar
I don't have ac. My temps were only a little above normal with the fan on.
Old Jul 25, 2011 | 01:30 PM
C_Rules's Avatar
my temps were way above normal but so was the temperature outside. car normally runs around 180 with the a/c off. it was 100 degress at times and the car was running at like 235 with the a/c on.
Old Jul 25, 2011 | 03:53 PM
brians91formula's Avatar
Car never overheated but it sure did feel slow in that hot *** weather.
Old Jul 25, 2011 | 04:32 PM
02gangsta/ss's Avatar
didnt have the car out but omg i have a 9 zone sprinkler system and my water bill is going to be ******* outrageous !!!!!
Old Jul 25, 2011 | 05:18 PM
C_Rules's Avatar
so your car was running at its normal temp?
Old Jul 26, 2011 | 10:22 AM
A little higher than normal but not much. Nothing for me to worry about. Although I was not sitting in traffic either...
Old Jul 26, 2011 | 11:28 AM
C_Rules's Avatar
did you have the a/c on? i'm just cruious with my a/c on my car was running like 50 degrees hotter.
Old Jul 26, 2011 | 11:32 AM
metalmilitia606's Avatar
My car was running pretty close to normal. If I had the ac on and I was stuck at a red light the temp would creep up a tad, but nothing to worry about.
Old Jul 26, 2011 | 11:52 AM
tektrans's Avatar
235 is up there man. I mighta shut mine down or at least turn heat on if she hit 230.
Old Jul 26, 2011 | 12:18 PM
C_Rules's Avatar
for an lt1 its not bad because of the reverse cooling. still i have a 160 tstat and programmed the fans to come on early so i was surprised to see the temps that high. but then again it was 100 degrees outside. i have to drive around for a while with the a/c off. if the temps start creeping to like 200 then i'll know somethings up. usually i run around 180 with the a/c off.
if the temp with the a/c off is normal but creeps up like 40 degrees hotter when the a/c is on what could be wrong?
Old Jul 26, 2011 | 04:43 PM
ls1curt's Avatar
I did a ton of driving this past weekend and never saw above 185. I don't have A/C though. I wouldn't be driving with 235 degree temps though. I was happy not to have any temp issues with the new turbo setup.
Old Jul 26, 2011 | 05:04 PM
703 CAMAROSS's Avatar
I was working in a garage all day every day with no AC. I think I lost about 3 pounds just from that lol. People kept bringing there cars in for oil changes and burnt my hand about 5 times hahaha
Old Jul 27, 2011 | 07:04 PM
sdm1234's Avatar
My car was running just as cool in the hot weather because of my electric water pump. Mods are in my sig link.
