1999 C5 with 136,000 miles
You want to know if the radiator and battery and alternater had been replaced. The water pump lasts a little longer but that would be a huge plus if the water pump were replaced already. If the tranny is slipping or you here a ticking or knocking in engine then don't buy it. Other wise do not get scared of the miles. Pay $9,000.00 - $12,000 for the car. Good luck.
Internet Mechanic
Anything 80K and up you should be looking are wear items. Owner should have work done and recipts to prove it. A good under chassis inspection wont hurt. IF your not mechanically inclined, pay a shop to do it.
If the owner has not dont much in the upkeep dept, you should not be paying what he wants.
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
1 Post
Mileage doesn't matter if the car has been taken of. I'd look at the suspension and check to see if the car had problems with app and traction/control. Also the clutch and torque tube.
