Will an exhaust cut out pass inspection if its before the cats? In va
Can anyone help me with this? I'm trying to find away to get around using cats so any help will be appreciated
I just swap my ORY and my catted Y when inspection time comes. I just tried to get through safety with the ORY and failed...yes, they actually looked under my car. I guess it will depend where you go, but it only took me about an hour to swap my y pipes tonight.
Good luck!
Good luck!
Isn't the whole point of a cutout to be able to control it and thus the exhaust volume?
So why not have the cutouts be closed when you go for inspections and be the same exact thing as not having a cutout to begin with?
With a properly installed and sealing cutout, the exhaust volume will be literally the same as before the cutout when the pipe was fully intact. So if you can pass with that, you can pass with a CLOSED cutout just as easily. Now if your cutout is leaking yeah you may not pass because it's gonna be friggin' loud with an exhaust leak near the cylinder heads.
just visual and obdII on obdII equipped vehicles...to the op it really depends on where u go. For instance on my old car i had heads/cam and true duals with turndowns and the car was loud as hell and they never even looked under my car for cats yet with the car i have now i have boltons and an slp dual/dual on it which is much quieter and for some reason they were checking underneath my car for cats
