Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
first runs
Old Jul 16, 2005 | 10:53 PM
slayer_taunu's Avatar
Default first runs
had my first runs ever this weekend at NED. best time was a 13.54 @ 106.xx
most of the time i was running a 14.0 cuz i havent figured out how to launch yet. i was mostly getting hideous 60' times of like 2.6 , except my 13.54 run, i got a 2.3 second 60'
i will be needing more practice... pronto. if i had a clue what i was doing, i would think i could be running low 13's with more practice.
Old Jul 16, 2005 | 10:57 PM
badpewter-z's Avatar
LS1TECH Sponsor
cut the sixty to 2.0 or lower and ya have 12's
Old Jul 16, 2005 | 11:34 PM
BADFNZ-383's Avatar
13.5 aint bad at all for your first time out man. some more seat time and you should see some dam good times
Old Jul 17, 2005 | 08:36 AM
Noyzee's Avatar
8 second mod
with more time, and the new stuff going on, that car should go 12's easy.
Old Jul 17, 2005 | 12:00 PM
ok, well is a 2.0 60' a reasonably attainable time with street tires? (KDW's) i dont really have the funds to get a 2nd set of wheels and tires for track duty, nor do i want to really use drag radials as daily driver tires.
Old Jul 17, 2005 | 12:31 PM
LS1TECH Sponsor
yes and no
it will come at the cost of replacing more clutches. youll have to slip it more so not to spin to bad but it is a reachable spot
dr's arent bad on the street at all ive had my nittos well over 120 with no issues at all even in the rain i havent had any issues and if your easy on them you can get 20000mi outta a set including some track use. best part is all you have to do is air down , run air up and your on your way
Old Jul 17, 2005 | 03:54 PM
02CamaroZ28's Avatar
yes and no
exactly, I had the best launch on nittos slipping at 3500.
Old Jul 17, 2005 | 04:25 PM
Noyzee's Avatar
8 second mod
i had better luck with drag radials, and they last longer then 3,000 like everyone says, i had them for probably 6k and passed them on to a kid who put atleast 2k on them.
same with tim, his old ones we just changed, hell B-Man had 5k on them and sold them to tim who put atleast 2k on them, that was with lots of passes on them, and they hook better.
But yes, 2.0 is doable even with the tires you have. when i was bolt on, my car would 1.9-20 on a treated track. with KDWS's same size and similar mods as you.
Old Jul 17, 2005 | 04:29 PM
well then it looks like its back to NED on friday for some more practice!
hopefully i wont be doing this , like i did last friday
Old Jul 17, 2005 | 05:17 PM
nikon1999's Avatar
the way matt drives were going to have to put heads & a cam on his car before he can bust out a 12
Old Jul 17, 2005 | 06:21 PM
no no, that will just make me spin my tires off the line even more
