Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
help...
Old Sep 21, 2005 | 12:33 AM
anthonyz281999's Avatar
Default help...
my car just ran out of gas ... then we put 10 dollars of gas in it and it wont start....it will idle really badly for a little then stall... i need to get it home bad can anyone help me .. of wat could be wrong
Old Sep 21, 2005 | 03:40 AM
bspz28's Avatar
Fuel pump went .. The gas is what keep the fuel pump cool and when you run out of gas and try to start it you tend to burn the pump out.
Old Sep 21, 2005 | 05:32 AM
Slowhawk's Avatar
LS1Tech Sponsor
That's it. These pumps ussually burn out if the gas runs out.
Old Sep 21, 2005 | 04:48 PM
http://cgi.ebay.com/ebaymotors/98-02...ayphotohosting
is this the right one for my car ?
Old Sep 21, 2005 | 05:25 PM
Slowhawk's Avatar
LS1Tech Sponsor
You don't need the whole tank. Just a fuel pump.
Old Sep 21, 2005 | 07:04 PM
LoudmouthLT1's Avatar
Racetronix sells a replacement walbro pump. I just installed one this weekend by cutting the access hole in the rear deck and it was pretty easy.
Old Sep 21, 2005 | 10:47 PM
BubaGumpShrimp's Avatar
you sure he has enough gas in the tank if he ran it dry, 10 bucks doesnt go far these days
Old Sep 23, 2005 | 11:49 PM
so where do i go about cutting ???
Old Sep 24, 2005 | 08:01 AM
I did this on an LT1, I'm not sure if the tanks changed or not. I have pics of the whole process though, here is where you cut. I can get the exact measurements later on today.
Old Sep 24, 2005 | 08:03 AM
When you get through the deck you will see the fuel lines and the top section of the pump assembly on top of the tank Just don't pry off that wiring harness because you are not supposed to unplug it.
Old Sep 24, 2005 | 02:00 PM
ok so this is that hump behind the back seats..then after i get to this point i just undo those bolts and the old fuel pump is underneath that? then just swap it in with the new one right??? also any clue to where the filter is on the car....thanx for the help
Old Sep 24, 2005 | 02:13 PM
NLinnear's Avatar
Drop the gas tank instead of cutting up your trunk
Old Sep 24, 2005 | 02:20 PM
isnt it a lot of work to drop my tank ?? like u have to take the rear end out ?
Old Sep 24, 2005 | 02:26 PM
NLinnear's Avatar
Remove the panhard rod and brace, drop the exhaust, remove the bottom shock bolts( this will allow the rear to drop), remove the heat shields, remove gas filler door and the one bolt in the filler neck, disconnect the lines, and remove straps. Looks like more work than it is and you are not cutting up your car. I guess if you are doing it to your own car and you don't mind, that fine. Just make sure that if you sell the car, tell the buyer that you cut part of the trunk
Old Sep 24, 2005 | 02:33 PM
got any clue where the fuel filter is ?
Old Sep 24, 2005 | 02:37 PM
NLinnear's Avatar
Driver side just past the rear wheel.
Old Sep 24, 2005 | 02:47 PM
thanx
Old Sep 25, 2005 | 02:02 AM
Well the filter is inside of a bucket thats located on the fuel pump assembly which is kinda big. You need to break the glue seals on the bucket then take the pump out, install the new one and let the new glue dry to seal the bucket. Then you reinstall heres a pic of the bucket and actual fuel pump. This is the assembly and this is the pump itself which is inside the bucket which is the tan thing at the bottom.
Old Sep 25, 2005 | 02:04 AM
Now don't get me wrong here, the correct way is to take the tank out but some people have their exhaust welded so it makes it more of a hassle to cut it and then have it re-welded. This car was a 95 and has 125k or so on it so theres no real worry about market value later on. This way didn't take long and it worked like a charm. The biggest reason to do this was incase the pump turned out to be junk or we forgot to connect something we could just go in again through the access hole in a few minutes.
