Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
new best yesterday
Old Oct 22, 2007 | 08:03 AM
BlazinT/A's Avatar
Default new best yesterday
a couple of my friends and i went to the track yesterday got myself a new best. No matter how i heated the tires they just kept spinning, next year im going with real slicks. any how i ended up getting in 8 runs
the best
60' - 1.852
1/4 - 11.941
mph - 118.78
Old Oct 22, 2007 | 08:16 AM
BlackScreaminMachine's Avatar
Internet Mechanic
What tires did you go with this time?
Other then BMR LCA's, anything else?
What PSI on said tires.
What Launch RPM.
And were burnouts done with the help on Line lock or did you foot brake it?
Old Oct 22, 2007 | 09:45 AM
DannoWS6's Avatar
Nice, the car is really moving out!
Old Oct 22, 2007 | 11:38 AM
rdm85mcss's Avatar
Congrats on hitting the 11's. Your car is sweet!
Old Oct 22, 2007 | 12:19 PM
BlazinT/A's Avatar
What Launch RPM.
just sub frame connectors and lca's, i was running 16 psi on a set of mickey thompson radials and launching at about 3500 ish. i have a linelock kit and i did some nice 7 second burnout but the tires just wouldn't hook, i think it was the way i was launching, i ended up slipping the clutch the last run and got the 11.9
Old Oct 22, 2007 | 01:15 PM
Internet Mechanic
The car needs a Adjustible TQ arm and LCA relocation Brackets, if I recal 9" don't have in their casting lower mounting holes.
Also some long burnouts will help too.
If you have M/T ET radials, they are a hell of a tire. I make stockish power and I couldnt get mine to hook even with a Adjustible TQ arm and relocation brackets until I did a proper burn out. I did a 5000 rpm clutch dump and it dead hooked to a 1.82 with making like I said stock power + whats in the sig and running on a stock/unmodded tune. If I went off the limiter, it prob would have ran a 1.7X
The last thing to think about is the quality of track, the track temp and if ricers are dragging water off of the box, those dont help either. When you burn out, its ok to spin for a split second in the box and roll to the burn out pad, do the burnout and roll out and you should feel the tire BARK and grab hard.
Old Oct 22, 2007 | 01:50 PM
99zman's Avatar
congrats Brandon, nice time, was that with a new set of mickey's??? or you bald *** ones? LOL..
Old Oct 22, 2007 | 02:37 PM
Slowhawk's Avatar
LS1Tech Sponsor
Nice,even with the stock heads. I guess you figured out the coil code?
As for 60's just keep practising.They will get better and so will the times.No need for suspension stuff till you can feel what the car is doing,then control it.
FYI-I ran 1.80 60's with my stock Firehawk tires.No need to mask driving yet with a slew of suspension and tires.6 speeds take finess.
Old Oct 22, 2007 | 02:39 PM
Slowhawk's Avatar
LS1Tech Sponsor
And why haven't you hit the track yet
Old Oct 22, 2007 | 03:43 PM
BlazinT/A's Avatar
well wefigured out that the scan tool i have letters the coils instead of numbering them, so we swapped the #5 coil to the #4 coil spot to see if it would act up on the #4 spot and the code hasnt come up since. im thinking it was just the way the coil was grounded on the bracket.
Old Oct 22, 2007 | 03:47 PM
My84Z's Avatar
Congrats Man!!! stock heads and all that bitch is moving!
Old Oct 22, 2007 | 04:52 PM
99zman's Avatar
LOL... how did i see that comming. i will actually be calling you probally tommrow about some things i would like to have done until i read one of your other posts. I havent been driving it a ton, my bike either. it sucks.
Old Oct 22, 2007 | 08:47 PM
badpewter-z's Avatar
LS1TECH Sponsor
not to shabby man
Old Oct 22, 2007 | 10:31 PM
Speedy0009's Avatar
As for 60's just keep practising. They will get better and so will the times. No need for suspension stuff till you can feel what the car is doing,then control it.
Nice time man... Congrats on joining the 11 Second Club. Hopefully my stay in the 11's will end this upcoming Sunday.
Don's got a damn good point there. My GTO is on all stock suspension with a simple addition of drag bags! Tire choice plays a big role too unless you like to learn the specific launch with what you have, (ditch the Automatic made tires for some real slicks). Watching the video footage I can gather what the car needs to go quicker as well as the feel while driving... Next year is going to be DAMN FUN!!!
Old Oct 23, 2007 | 04:37 AM
Internet Mechanic
Thats called slipping the **** out of a clutch and burning up to nothingness, then its called being on the T-56 clutch exhange program.... But you can call it finess...
Old Oct 23, 2007 | 07:29 AM
Slowhawk's Avatar
LS1Tech Sponsor
Actually it's called learning how do drive a car.Too many people use parts to make up for there driving.
Old Oct 23, 2007 | 07:44 AM
BlazinT/A's Avatar
if i get the money to go this weekend i might go back up but its not looking promising, i think that the car has an 11.7 in it but it may be next year until i get it
Old Oct 23, 2007 | 07:45 AM
02SCVette's Avatar
Agreed. Take notes from Ranger in his Z06. His clutches have looked great after hundreds of track passes with incredible 60' times. Not many can drive like Ranger and Don though....
Old Oct 23, 2007 | 08:01 AM
Slowhawk's Avatar
LS1Tech Sponsor
It's just practise and alot of it.I see people here getting faster all year with no car changes,just driving technique's.The advise I give is to run your car stock with stock tire's/clutch as much as you can to get the feel of launch.Then when you add power,tires,suspension you can feel the difference and drive with it. You see a ton of people add all the parts and run slower,then blame the car.
Mike- you get that damn clutch in yet!!!!
Old Oct 23, 2007 | 08:06 AM
BlazinT/A's Avatar
how do you guys hold the car in place when slipping the clutch
