Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
emissions help
Old Jun 10, 2008 | 02:49 PM
SheaMus's Avatar
Default emissions help
i just went to get my emissions done...No Dtc's....i didnt pass because the System Readiness test [EPA] was not ready....I hooked up efi live....i had no dtcs but i clicked the clear code...cleared....then drove the car around for 2 hours...still the same problem...anyone know if its a bad pcm?? or something else?
Old Jun 11, 2008 | 01:04 AM
Tom01ss's Avatar
Yo Shea,shoulda ask fran.He would of told ya what the problem is.You have to have some many start/stop cycles for the codes to disappear.It's like 10/20 cycles. Do that and go get the car done it'll pass then.
Old Jun 11, 2008 | 09:26 AM
massls1guy's Avatar
Did you happen to disconnect your battery before you went for the test. That will make the tests run again.
Here is the test cycle:
http://www.obdii.com/drivecycle.html
And this sticky also has some good info:
https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html
Old Jun 11, 2008 | 10:05 AM
BlackScreaminMachine's Avatar
Internet Mechanic
When it shows your not ready, you havent drove enough cycles. I would do multiple drives AND have the car turn on and off quite a few times.
TO give you an example, with a aftermarket tune and a lumpy cam.
The computer has a updated tune based on the place that does it, but the driveability stuff takes time to be made. Like I would have the atypical hanging idle when driving and when I come to a stop, it drops.
It took over 10 drives and for at least the car to hit closed loop for it to cease happening.
Think of the readiness test like that, the PCM needs so many drive cycles to set.
Old Jun 11, 2008 | 01:29 PM
SheaMus's Avatar
thanks guys...ill drive this around on ...mp on 95 do the 55 mph and drop then see what efi live says...thanks again guys
Old Jun 11, 2008 | 03:49 PM
Slowhawk's Avatar
LS1Tech Sponsor
Forget driving it around,won't help.
Delete every code for the 02's and EVAP system.Then it will pass 5 minutes later.Also EFI live has a emmisions ready test. I bet your car failed 02 and EVAP readiness.
Old Jun 11, 2008 | 04:06 PM
Internet Mechanic
Unless there is something funky in the tune, it will help to drive, or more to the point get the cycles in.
IF he can just tune all the rest of the **** out, thats great but thats up to him or his tuner to do so.
At least he is lucky, in CT if he doesnt past the PCM test, he HAS to pass on a emission roller.
Old Jun 11, 2008 | 04:52 PM
Slowhawk's Avatar
LS1Tech Sponsor
Ok,if you delete the rear 02's it will never pass a 02 ready test!!!!!
Cycles mean absolutely nothing if you have EFI live.It will pass 5 minutes after you download a tune. I didn't read anything about how the car drives--- just how to pass the test.
Believe me,I've been through this a hell of alot more times than you have.
Old Jun 11, 2008 | 05:41 PM
Internet Mechanic
Based on the post he seems to NOT have an SES/Emissions/DTC issue, just that he had cleared everything.
So an FYI for everyone else if you dont have EFIlive, or access to a tuner whom you can pay to have it done then do what I say. BUT if there is a SES/Emissions/DTC issue, then it needs to be solved before going back.
Last edited by BlackScreaminMachine; Jun 12, 2008 at 07:54 AM. Reason: clarification
Old Jun 11, 2008 | 09:08 PM
SheaMus's Avatar
I drove and did cycles all day...on and off...up above 55 then left off the gas and let it roll down...put efi live back on...02's and evap passed...just saying that EPA readiness test isnt ready...its wierd...i saved my tune...and downloaded the stock tune off of efi live and just flashed it back to stock...iam gonna change the speedo for the rear and go take it for a ride again...hopefully it was something that was put in the pcm...thanks for the feedback guys...ill write up and let u guys know what happens
Old Jun 12, 2008 | 07:21 AM
Slowhawk's Avatar
LS1Tech Sponsor
Just read my post again. They will never- ever be ready! Delete what I said and it WILL pass.
Old Jun 17, 2008 | 04:26 AM
Speedy0009's Avatar
He's not kidding around it certainly works! Just listen to Slowhawk, he knows what he's talking about! Had this done last month and the car passed when I took it about 35 minutes later, when I got to the service station!
Old Jun 18, 2008 | 11:21 AM
SheaMus's Avatar
guys thanks for the help...slowhawk...i did everything u said...removed everything...i still have on more prob...the secondary air system still showing not ready.....Can i remove the codes for both air systems also??? and do you recommend turning everything back on after i get my emmissions passed?
Old Jun 18, 2008 | 11:46 AM
Slowhawk's Avatar
LS1Tech Sponsor
Yes,delete all of the AIR system codes.Most cars we get rid of the AIR system anyways.
Old Jun 18, 2008 | 12:13 PM
SheaMus's Avatar
thanks man
