Need ABS InOp codes cleared in NNJ
anyone in the NNJ area, Morris/sussex county that can clear codes?
I went to the track and since then my ABS Inop light is on. Just need someone to clear codes if any.
thanks
thanks
CARTEK Racing
It should go away on its own, I don't think its a DTC, so I don't think you can "Clear" it with an auto-tap or the like.
I've had an ABS INOP light come on a few times after multiple dyno runs or driving around a long time on skinnies and slicks. But they have always gone away.
I could be wrong though...
But from what I have seen, people who remove their ABS, have to disable the light, no way to make it not show up.
CARTEK Racing
That may be a different issue, but I know different size wheels/tires can throw and ABS-INOP light. Even a tire that is underinflated and therefore shorter, if driven for a long time can probobly throw that light.
yeah, well I did have Drag radials that were underinflated...wonder if that caused the ABS light. Never did before. In any case it hasnt gone off yet and I disconnected the battery, reset the PCM, checked the ABS Bat fuses. Maybe I need to get on it again..
