Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Need some help with exhaust, header mostly
Old 09-17-2008, 04:53 PM
Z28Red01's Avatar
Default Need some help with exhaust, header mostly
How long and how hard is it to install headers?
Has anyone had theres done and can give me some equipment i need to do it.
Also if you've takin it to a shop how much was it.
Old 09-17-2008, 05:16 PM
Moderator
davered00ss's Avatar
Shop is probably $500-$700 labor. Doing it yourself the first time will probably take you a day.
You don't need a lot of tools. It can be done on jackstands in your driveway. www.ls1howto.com www.installuniversity.com
Old 09-17-2008, 05:17 PM
Moderator
A friend to help is almost necessary. Can be done alone, but easier with an extra set of hands.
Old 09-17-2008, 05:20 PM
CJDZ24_Z28's Avatar
a friend,a couple of jackstands and a good set of tools if you search there is tons of info on this. good luck
Old 09-17-2008, 05:30 PM
Z28Red01's Avatar
anyone give me a direct link to it for a 2000 z28, i cant seem to find it.
Old 09-18-2008, 09:14 AM
massls1guy's Avatar
The dynatech install manual is pretty good:
http://lib.store.yahoo.net/lib/after...odyinstall.pdf
Fyi, I found the link here:
http://www.afterthoughtsauto.com/ls1-headers.html
Old 09-18-2008, 05:51 PM
Z28Red01's Avatar
Thanx for the help everyone.
Old 09-18-2008, 06:49 PM
Frans96SS's Avatar
wow 5-700 is ALOT i think... i charge 400. give me a call if i can help you out.
Old 09-18-2008, 06:57 PM
lastcall190's Avatar
1. Give yourself a whole weekend if it's your first time. Overkill? Probably. But first time with anything on the car should NOT be rushed IMO. Hard? I don't think so, take old **** off, put new **** on
2. https://ls1tech.com/forums/showthrea...&highlight=arh
Get yourself some good angled head ratcheting gear wrenches! 10mm will save your ***...
3. The only LTs I didn't install myself were on my LT1... it cost, enough. Good news is I saved every last bit of sanity I would've lost attempting it!
Oh and the quality of parts could also dictate the ease of install. Good luck if you do it yourself, if not, there should be plenty of shops near you that could do it.
-J
Old 09-18-2008, 07:40 PM
Z28Red01's Avatar
ya i got pacesetters and I've heard they are the easiest to put on. Trying to work a few angles with people see how it comes out. The rest is a TSP Y-pipe with cat and a magnaflow exhaust(thanks to speedtweekerz and TSP).
Old 09-18-2008, 08:01 PM
Frans96SS's Avatar
DEFF not the easiest to put on.... American Racing Header has that title.
Old 09-18-2008, 08:12 PM
fatdave's Avatar
+1 on the ARH they are great and were so easy to install by my self
Old 09-18-2008, 08:20 PM
I've installed both and ARH is easier, but don't worry Pacesetters are still easy. ARH are just, easier... the Pacesetter horse has been beaten countless number of times in the External section
-J
