Looking for a place to shorten rear
Hey guys hows it goin? I was just wonering if yall knew a place I could take a rear and get it shortened along with the axles? My buddy broke his rear yesterday at the TNT and we are looking into doing the ford 8.8 in his car. So if you know anyplace local that can shorten a rear please let me know. Thanks in advance
Daniel
Daniel
Advanced driveline on Carter Rd in Orlando near the old Ben White horse track off lee rd. They can shorten and respline the rear. But I would Listen to N2OMIKE, spend the $ and get a pair of good axles all ready done, I had a bad experience with a resplined axle. They can order any length from Moser and then cut and weld your diff tubes.
I can narrow the housing for you - how much does it need to be narrowed?
There is nothing wrong with cutting and re-splining the stock shafts. The problem you run into is that most shafts neck down and the diameter of the shaft becomes smaller and you can't machine it to the same diameter.
Your best bet would be to have Moser build you some axles.
Thanks,
David
Thanks,
David
Hey david, I you didn't even pop in mind when I thought about this lol. But yea I will talk to hunter or brenton today and get your number and give you a call. Thanks alot
Daniel
Daniel
