OSW this Friday? Forecast is low 50's, 10% chance of rain
Anyone going to OSW this Friday?
I was planning on waiting till next Friday, but the forecast shows low 50's. I don't think I want to pass that up.
Say between 5:00 5:30 (track opens at 6:00) at the Whataburger at the corner of Colonial and Chulutoa.
Google map:
http://maps.google.com/maps?oe=utf-8...,0.209427&z=13
Google map:
Plans are firming up for me. I don't think I'll be able to meet before hand, but I hope to be arriving at the track around 5:45 - 6.
Won't quite be low 50's (upper 50's overnight), but still probably cooler than it will be in the upcoming weeks. Here is a hourly chart for tomorrow.
http://www.weather.com/outlook/drivi...rom=hrly_graph
Hopefully we can get some more tech members out there. Always good to hang out in real life too.
Thanks Justin.
1st run (first time ever launching with cam/converter)
1.719 60' - 11.95 @ 114.5
2nd run (hot lapping)
1.695 60' - 11.92 @ 114.4
Runs 3 and 4 hit the limiter on the 2-3 and the 60 ft times were 2.0's .
Maybe I was brake/stalling to high (2400 rpm) on the 3rd and 4th and not hitting the tires as hard. I only stalled it to 1500 and 2000 on the first two runs. Not sure why else it was only cut a 2.0 60'. Maybe the 2-3 limiter was because the clutches are getting worn, trans was hot .
The 2-3 shift on the limiter could be clutches or maybe the shift point is too close to the rev limiter. I also found with my car if i run in D(overdrive) the car shifts much more firm into 2-3 shift then in 3rd(drive). In overdrive the car does not use the overrun clutches, in drive it uses the 3-4 clutch pack and the overrun clutches which is apparently to much fluid volume for a 13 vain pump to supply and it causes the car to flair or even hit the limiter on the 2-3 shift. If your trans does not have a 10 vain pump that is probably the problem and you just need to race in D (overdrive).
If you stall it too high the converter wont flash much when you leave so it hurts the 60'.
Oh well. The 1st two runs were just what I was hoping for!
