Compression and leak down tests
Thanks!
https://ls1tech.com/forums/generatio...92-intake.html
When I didn't gain anything from the Fast 92 makes me think something is amiss.
I ordered the cam through Mike Norris, and he also built the shortblock. I requested he degree the cam and I don't have any reason to believe he didn't.
if it needs work, i recommend whistler ive seen his epoxy port work first hand its amazing.
The only other time I have seen a FAST not do much at all if on a set of poorly flowing heads. And keep in mind that a head may have good number with an open port, but two heads with the same CFM on an open port can have quite drastically different numbers with the intake bolted on.
If need be Jimmy we can do the leak and compression test here and on a weekend if need be. Let me know if the other offers pan out or not.
Mike Norris
Weekends seem to be best because the car is outside and poor lighting to work under the hood weekday evenings.
It appears that the FAST needs some TLC during re-assembly regarding preventing leaks, etc?
92slowmaro: I'm PM'ing you my cell number.
Cylinders 1,2,7,8: 160
Cylinders 3,4,5: 165
Cylinder 6: 170
That was with turning the engine over ~3 times. Whistler thought with the SCR of 11.4 that it should reach a higher number, so we re-tested #1 turning over ~6 times, and that yielded between 195-200. I inferred there was a question on why it didn't build more compression sooner.
The port alignment between the intake and the heads was off about 2/16" of an inch on the floor of intake port 1. Intake gaskets are red, which I presume are the FAST gaskets.
You mention that the port alignment is off 2/16" (1/8") whihc is a bit, but as long as the step is getting bigger going to the head not a big deal. Now if the port on the intake is larger then the port on the head creating a step up, then there can be a bad flow issue even at 1/8".
Mike Norris
Mike Norris
