Florida Members Fun, sun and LS1's
Need a LT1 Tuner!!
Old Aug 24, 2009 | 12:52 PM
Trevor.j's Avatar
Default Need a LT1 Tuner!!
i have a lt1 car that was originally tuned by Jeremy Formato.(the car runs great intill wot) but out of no where, it seemed like the tune or shift points have been out of wack. it only happens at WOT, and it seems like the car is trying to shift over the redline. and it happens in every gear, and in every mph. i dont know if you can help me out with this or not? i can get video of the car doing it, also. i hopefully have someone that can help, just waiting on his response. The mods are
Engine:
GMPP 218/228 .525"/.525" Cam
GMPP 1.6 Roller Rockers
GMPP LT4 Valve Springs
GMPP Lifter Set (Replaced at 78,7XX miles)
Hypertech 160* Thermostat
Exhaust:
Pacesetter Ceramic Coated Longtube Headers
3" Off Road Y-Pipe & Custom 3" Catback
3" QTP Cutout
Flowmaster 40 Series Muffler with Dumps
Drivetrain:
Pro-built Automatics Rebuilt 4L60E with cryoed reverse/input drum and HD sleeve
Transgo Vacuum Modulator & Transgo Stage II Shift Kit
PI Vigilante 3000 Stall
LS1 Aluminum Driveshaft with Lakewood Performance U-Joints
B & M Tranny Cooler
T/A Performance Rear End Girdle
Suspension:
Spohn Tubular Lower Control Arms
Spohn Lower Control Arm Relocation Brackets
Spohn Strut Tower Brace
Spohn Subframe Connectors
Ignition:
NGK TR5 Spark Plugs
MSD 8.5" Super Conductor Plug Wires
MSD Ignition Coil
LT4 Knock Module
Jeremy Formato Dynotune
and the car is a 94 if it helps.
thanks Trevor
Old Aug 24, 2009 | 12:54 PM
Trevor.j's Avatar
im also located right next to O.I.A. and would like for the closest person. but if i have to drive a good distance then i will.
Old Aug 24, 2009 | 02:18 PM
jimmyblue's Avatar
Moderator
Take a look at the matted TPS voltage and make sure
that is less than fault threshold (I don't know LT1s
but there is bound to be one, and misbehaviors if you
go over the top).
Old Aug 24, 2009 | 03:16 PM
thndrracer's Avatar
Pm "slow" on fuelslut he should be able to help you out.what's up with the ls1 car
Old Aug 24, 2009 | 03:50 PM
Trevor.j's Avatar
ok ill pm him. and lets just say i had some body damage. and just droped the car off to my body guy. so hope all goes well.
Old Aug 24, 2009 | 07:21 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
have you contacted Jeremy to find out his take? If you had it tuned by someone I'd contact them first on a problem.
Old Aug 24, 2009 | 07:46 PM
Trevor.j's Avatar
i have not. its been a while since the car has been tuned. and just wanted to get this problem taking care of. if i have to i will go to him. but the tune was and still seems to be spot on besides this problem. so im looking for a quick fix
Old Aug 24, 2009 | 07:58 PM
RsSean's Avatar
Did you get hit again? Body damage? Sorry if this gets off topic. LOL. Talk to Jeremey him or I think his wife responds back very quickly to Pm's or E mails.
Old Aug 24, 2009 | 08:22 PM
Mike Norris's Avatar
A tune does not just change and I would say that there could be a sensor or trans issue. Before you go making any tuning changes I would check out some other things first.
Mike Norris
Old Aug 25, 2009 | 11:31 AM
JuicedSS262's Avatar
Mike Norris
+ 1
I know Jeremy is up in PA tuning this week, but if you have any questions, feel free to contact him on his cell at 813 495 8778.
Old Aug 25, 2009 | 03:37 PM
97blkz's Avatar
Engine:
Exhaust:
3" QTP Cutout
Drivetrain:
B & M Tranny Cooler
Suspension:
Ignition:
NGK TR5 Spark Plugs
MSD Ignition Coil
LT4 Knock Module
thanks Trevor
A wild stab in the dark, check the throttle position sensor. I forget the volatge it needs to read but you can locate this info. Happened to me.
Old Aug 25, 2009 | 03:38 PM
97blkz's Avatar
go over the top).
Good answer , sorry I skipped over yours before posting.
Old Aug 25, 2009 | 06:17 PM
Trevor.j's Avatar
thanks guys i will check out all this before i go any further
