Anyone want to help me change my oil pan gasket and rear main?
its so hard to track down, there's a slow residual leak dripping from the bottom of the kmember, but where the oil is coming from, who knows ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I can't believe I fucked up on the timing cover like that, can I get that gasket lined up without taking the pulley off?
LS1TECH & Trucks Sponsor
You should be able to do that without taking the balancer off, but it's rather suspect IMO that the crank seal is leaking too, because it seems likely that it is getting on the balancer to get slung up on your alternator and such. Honestly, I would pull the balancer and cover and replace the crank seal and the timing cover gasket too just to make sure you know that it's all in the clear up there.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Ok, got a new crank seal and timing gasket. Installed the pulley with the cover loose, then tightened it. Made sure gasket went in right too. And of course I lose one of the water pump bolts, don't ask how, i have no ****** clue. Haven't tested it yet, will tomorrow.
Demitri If you are still having problems you can bring it over to my house if you don't have a garage to work in. Hope everything is working out for ya.
