Florida Members Fun, sun and LS1's
Diagnostics Help
Old Aug 28, 2010 | 08:56 AM
chobes's Avatar
Default Diagnostics Help
Anybody in Central Florida available to help me figure out what happened to the car? Car is a '98 TA, stock except for mid-length headers, just turned 100k.
Problem:
I noticed a miss at idle a couple of times, but the car ran fine. Yesterday it started running like a tractor, feels like it's running on 5 or 6 cylinders only. I don't have any way to test anything myself other than look at the plugs or change fuel filter.
Any suggestions? Anybody available for me to bring the car by?
Old Aug 28, 2010 | 09:28 AM
396D1SS's Avatar
whens the last time you put in new plugs and wires?
Old Aug 28, 2010 | 09:35 AM
chobes's Avatar
Thanks for the prompt response.
Plugs/Wires have about 10-15k on them, can change them easily....
Wondering about fuel-pressure, have heard a high-pitched whine from the fuel pump on occasion, but I don't have any way to test the fuel pressure.
Old Aug 28, 2010 | 11:45 AM
chobes's Avatar
Plugs look fine, catch can was full of oil, still runs like a dog...
Anyone have a scanner to see if it's throwing any codes?
Old Aug 28, 2010 | 11:52 AM
blk/slvr02ss's Avatar
When its @ idel does it go up & down ?
Old Aug 28, 2010 | 11:53 AM
cgperformance1320's Avatar
where u at in orlando ?
Old Aug 28, 2010 | 11:55 AM
chobes's Avatar
Idle doesn't go up and down, but it's rough... Feels like it's not running on all 8...
I'm located in SW Orlando, MetroWest area near Universal Studios...
Old Aug 28, 2010 | 12:04 PM
Does it clear up once your driving it @ a steady speed.
Old Aug 28, 2010 | 12:09 PM
chobes's Avatar
It doesn't clear up after driving, although I've only driven it short distances. Would prefer to figure out whats going on without driving it too much
Old Aug 28, 2010 | 05:26 PM
chobes's Avatar
Took the car for a bit longer drive, seems like it's clearing up.
Wonder if the amount of oil in the catch can was causing oil to get into the intake? Time to look into the intake and see what's in there....
Any other suggestions/thoughts?
Old Aug 28, 2010 | 06:44 PM
Erik@Lashway's Avatar
Take an hour, pull the intake, and look at the intake ports on the heads...if there's a lot of oil in and around the port, you may have been comsuming excess oil which could have caused detonation...be careful not to break of the oil pressure sending unit!
Best way is to let a shop with a scanner or tech II take a look.
Erik@Lashway
Old Aug 28, 2010 | 09:52 PM
chobes's Avatar
Erik,
Thanks for the advice, going to pull the intake tomorrow and see how it looks. Would be nice to have an LS6 intake to swap it while I'm at it...
Old Aug 30, 2010 | 07:01 PM
Not a problem brother, call us if you need help!! That's why we're here.
Erik
Old Aug 30, 2010 | 11:35 PM
chobes's Avatar
Got the intake off, doesn't appear to be any excess oil in the intake ports on the heads, just 100K miles worth of buildup....
On the plus side, it only took 35 minutes to pull the intake...
Attached Thumbnails Diagnostics Help-08312010.jpg   Diagnostics Help-08312010-001-.jpg   Diagnostics Help-08312010-002-.jpg   Diagnostics Help-08312010-003-.jpg
Old Aug 30, 2010 | 11:41 PM
DYING BREED's Avatar
fuel pressure check? when was last time you replaced fuel filter? where do you get gas? do you use sea foam or other cleaners?
Old Aug 30, 2010 | 11:49 PM
chobes's Avatar
I don't have a gauge to check fuel pressure, will have to get one. Fuel filter has been replaced, don't remember where I bought the last tank of gas from, haven't used any cleaners such as seafoam.... Might have to do that this weekend, or the chrysler cleaner....
Old Aug 31, 2010 | 08:04 AM
MikeNorris's Avatar
Have you had the ECM scanned yet to see whats up? Is there and SES or Check Engine light on?
Usually is there are misfires it will set a code and a Tech2 will tell you exactly which cylinder(s) it is.
A broken or bad valve spring can also cause what you have going on.
Bad oxygen sensor reading, false lean or false rich, can cause improper fueling on one side of the engine.
Definitely get it scanned as it will take out a bunch of guess work.
Mike Norris
Old Aug 31, 2010 | 08:14 AM
corvet786c's Avatar
Mike Norris
Mike when u coming back to fla for tuning.
Old Aug 31, 2010 | 11:22 AM
chobes's Avatar
Mike Norris
Mike, good to hear from you. I'm going to have it scanned this week when I get some time, need to put it back together first.
The pics i posted are from a cell-phone camera, but do I need to do anything about the build-up in the intake ports? The intake itself is pretty clean...
Old Aug 31, 2010 | 12:16 PM
MikeNorris's Avatar
corvet786c, I am thinking it will most likely be early October. Quite a few race weekends coming up next month, and then a trip to the country of Panama for a week to work on a new Z06 along. Between these trips and with things here being quite busy has my time alloted pretty far out for now.
chobes, just a good cleaning with some rags will be fine on the intake and ports for now. Was the SES light on?? let us know what you kind out after scanning her.
Mike Norris
