FS:2007 Yamaha Wolverine 450 4X4 Special Edition
I am selling my 2007 Wolverine 450 4X4 Special Edition. It's in flawless condition and only has approximately 80 mile. This is the best performance 4x4 quad on the market. It hauls *** and it fun to ride. I only had the bike for 3 months and it has to go by July. The only reason why its being sold is because in July I am re-financing my house and it needs to be off my credit to get a better interest rate. I paid $7400 for the bike and will let it go for $6,000 FIRM
You cannot even but a used 06 with low miles for 6k...Check on ebay, go to the yamaha dealership and look. This is also the Speical Edition....Here are the specs...I only have a few night pics of it but I can take more or even better come look at it in person...No joy rides period.
Engine
Type 421cc liquid-cooled w/fan SOHC 4-stroke single
Bore x Stroke 84.5mm x 75mm
Compression Ratio 10:1
Carburetion Mikuni 33mm BSR
Ignition DC – CDI
Starting System Electric
Transmission Yamaha Ultramatic® V-Belt / F,N,R
Engine Braking Front & Rear Wheel
Drive Train Yamaha On-Command® push button 2WD, 4WD ; Shaft
Chassis
Suspension/Front Independent Double Wishbone, 6.3” travel w/5-way preload adjustment
Suspension/Rear Swingarm, 7.1” travel w/5-way preload adjustment
Brakes/Front Dual Hydraulic Discs
Brakes/Rear Hydraulic Disc
Tires/Front AT23 x 8-12 radial w/aluminum wheels
Tires/Rear AT23 x 10-12 radial w/aluminum wheels
Dimensions
L x W x H 77.9" x 41.9" x 43.1"
Seat Height 33.1”
Wheelbase 48.5”
Turning Radius 118”
Ground Clearance 8.7”
Fuel Capacity 3.8 Gallons
Dry Weight 516 lbs
Rack Capacity N/A
Towing Capacity 1102 Lbs. (with optional hitch)
Other
Instrumentation Digital speedometer, odometer
Lighting Dual 30W Krypton multi-reflector headlights & 21/5W brake light
Engine
Ignition DC – CDI
Chassis
Dimensions
Seat Height 33.1”
Wheelbase 48.5”
Turning Radius 118”
Dry Weight 516 lbs
Rack Capacity N/A
Other
