Oiling for turbo's
Does anyone know what fitting I need? I would like to use a mechanical gauge since I'm doing a swap and will not be using the electric gauge.
Be sire to do your research, in relative talk, turbo's do not need a lot of oil. The amount will depend on the size of the turbo itself, IE a 61mm will require much less oil than a 91mm.
http://www.speedograph-richfield.com...ipe_lines.html
It replaces the brass oil gallery plug on the front side of the block and has a male -4 fitting,about $20.
Dominic
-3 and -4 for a feed line. I tapped mine above the oil filter. Many people run a restrictor in the feed line.
That fitting works bad ***!! It bolted up great on my truck. I used a 1/8 npt stait with -3 on the other end .
