Twin 76 first drive video.
Old Oct 20, 2008 | 02:02 AM
  #41
lemons12's Avatar
nice..
Old Oct 20, 2008 | 02:21 AM
  #42
13lu91rS's Avatar
the sound of that spoolup is absolute sexxx!
hope you find whats wrong with it
Old Oct 20, 2008 | 06:49 AM
  #43
Silver_TransAm's Avatar
With the cam u have u should be seeing more vacuum at idle. My car is running 10inches of vacuum at idle and my cam is considerably bigger. You might have a leak or the base tune could just be way off. The car is going to need a real tune for it not to die out when u stop. Ask me how I know. Never could get the damn thing to act right until i went to an SD tune, now no probs. Good luck with the car it is going to be sick.
Old Oct 20, 2008 | 07:42 AM
  #44
sevanseriesta's Avatar
here is a pic of all the plugs they all look identical
Old Oct 20, 2008 | 07:46 AM
  #45
98Camarod's Avatar
I had that intake and the gaskets they supplied me made me have a vacuum leak. I'd check around your manifold and see if you have a vacuum leak.
Old Oct 20, 2008 | 07:59 AM
  #46
conan's Avatar
Your plugs are on the rich side.
Old Oct 20, 2008 | 10:06 AM
  #47
That thing better not be leaking I just put new gaskets on it. I am thinking about putting my stock intake back on just to see if it make a difference.
Old Oct 20, 2008 | 10:08 AM
  #48
LOL, A little... I was really surprised when I saw that. However when I put the new ones in there was no change!
Can someone confirm that the harness for the 98 and 99 ls1 fbody are the same?
Old Oct 20, 2008 | 10:14 AM
  #49
98Camarod's Avatar
I'm pretty sure that they are the same also. I bought the msd blaster coils and they were for 98-02. You can use your same harness unless you are trying to eliminate the harness. Did the gaskets you used with the intake have holes punched in them for the head bolts that there? I tried everything to get it to seal, it wouldn't seal.
Old Oct 20, 2008 | 11:20 AM
  #50
I got the most up to date ones directly from PP themselves. So I am pretty sure that they did. I think I am going to try a different intake and see if that make a difference. I am going to worry about the miss first I think.
Old Oct 20, 2008 | 11:24 AM
  #51
conan's Avatar
Thats how rich my engine was running on the first start up. Take a extra set of plugs with you when you get it tuned. Also if you have a torch just turn the gas on and wave it around the intake if rpms climb = vac leak. I wouldn't drive it much with it that rich you could wash the oil from the cylinder walls and burn up your new rings.
Old Oct 20, 2008 | 11:55 AM
  #52
as promised here are the pics of the finished product
what my car looked like before FAD2BLK started working with it
after a little tlc
final engine shots
Old Oct 20, 2008 | 12:01 PM
  #53
Thanks bud, I have a couple set of the ar103's. That way if the need to be changed they can be.
Old Oct 20, 2008 | 12:23 PM
  #54
Josh@KY-Turbo's Avatar
Got to admit the turbo setup looks great . It nice to see it made it into a car finally. I cant wait to see some numbers. Keep up the good work.
Old Oct 20, 2008 | 12:25 PM
  #55
98Camarod's Avatar
Looks clean. Did you drop the k member to tap the pan? If so, why didn't you do a little rattle can clean up in the bay? Did you fab up the kit yourself?
Old Oct 20, 2008 | 12:28 PM
  #56
conan's Avatar
Looks as bad *** as it sounds!!!
Old Oct 20, 2008 | 12:45 PM
  #57
I did rattle can it so I am not sure which spot you are talking about....LOL I will also state that I did not build this to show it, so prettiness was not that important to me.
Old Oct 20, 2008 | 12:46 PM
  #58
I was not giving up on this set up.... You did fantastic work on this setup... I love it. I just got a couple bugs to work out.
Old Oct 20, 2008 | 12:50 PM
  #59
This is Josh's setup, he fabbed it (KYTP). I was originally going to buy one from him but he posted that he was to busy at the shop and was taking anymore orders. So I had to buy one from an individual that was selling it.
Old Oct 20, 2008 | 01:06 PM
  #60
The twin 76mm Setup was built in house by myself at Kentucky Turbo & Performance Inc.
The clean up on the car does look awesome. I have alot of work to do on my 02 Z28 to get the shine back.
