Twin 76 first drive video.
Old Oct 20, 2008 | 09:41 PM
  #81
sevanseriesta's Avatar
Originally Posted by reject
got a angle shot of the one on the passenger side? i wanted to do mine like that but couldnt think of a way to do it
You want a pic of the Turbo from the passenger side. Are you trying to see where it sits?
I will see what I have
Old Oct 20, 2008 | 09:42 PM
  #82
Reject's Avatar
yeah like how it sits and stuff like that
  #83
here you go reject
Old Oct 20, 2008 | 10:02 PM
  #84
MIGHTYMOUSE's Avatar
for starters those intakes give me the creeps
you running the stock computer?
i hate not being able to get under the hood through the screen, ive had so much dumb **** happen over the years i could find it in 5 min but to stare at the screen i am guessing.
what was the code?
yea by looking at the a/f assuming that little gauge is correct you could drop the base fule pressure until it gets into the 14's and see if it clears up going down the road.
if it does that is not a license to roll into it btw.
Old Oct 20, 2008 | 10:03 PM
  #85
LilJayV10's Avatar
Sick, that's just sick! Beats the hell out of an APS TT kit. Good luck with finding the problem and congrats on the baby!
Old Oct 20, 2008 | 11:06 PM
  #86
Thanks mightymouse did not even think about doing that with the fuel pressure. I am not trying to get into it at all..... All I am trying to do is get it so I know that there is not problems. I just want to drive it 20 miles one way and then back.
The codes showed no missed. It showed a MIL code not sure what that was and the other was a speed sensor error.
Old Oct 20, 2008 | 11:09 PM
  #87
Also I think the new set of plugs are already fouled out. Car will not even stay running at all and it sounds like it is rnning on 1 cylinder. I am going to put another set of plugs in tomorrow and lower the pressure and see if anything happens. I will try the wd40 test after I put new plugs in it tomorrow!
Old Oct 20, 2008 | 11:15 PM
  #88
LilJayV10's Avatar
How is your intercooler set up? I can't even see it in the pics.
Old Oct 21, 2008 | 12:18 AM
  #89
red90cobra's Avatar
just do the propane thing you'll get it all slick and greasy with wd40. then you got to clean it.
Old Oct 21, 2008 | 07:29 AM
  #90
here is how the intercooler is set up
Old Oct 21, 2008 | 02:22 PM
  #91
chub406's Avatar
i just statrted reading this thread. that car is sick! finely someone thought of the old school way! I've never heard of wd40. I've always used ever start. Just spray it on the vacuum lines and around the intake. the rpm's go up. its a vacuum leak. either( ever start) does a great job of evaporating. that way it doesn't leave the residue that wd40 does. just my .02. this is what iv'e always done through the years on carberated cars. cheap and works great.
Old Oct 21, 2008 | 03:21 PM
  #92
MIghtyMOuse, Thank you very much for your suggestion. YOur Idea made my car a whold different animal. It is amazing I thought that it sounded good before....Pfff, I should have video up in a little bit of the new changes.
I changed the plugs again... 3rd set in 2 days. Not bad. lowered the fuel pressure to 50, that was not low enough, went to 40 still to high, so ended at 28 and car runs like a dam champ. Thanks again new video up soon
Old Oct 21, 2008 | 04:21 PM
  #93
allbaugh_04's Avatar
i've been watchin this thread and i am glad you got things worked out. how much psi you gonna go, power you are looking to make?
Old Oct 21, 2008 | 04:26 PM
  #94
http://www.youtube.com/watch?v=nT1XxCcKdUE
That is the new video sounds like a totally different car....And it is windy and cold.... so please excuse the shaking
Old Oct 21, 2008 | 04:27 PM
  #95
15lbs to start probably, I am looking fro 9's to start and then will push it a little by little from there!
Old Oct 21, 2008 | 04:40 PM
  #96
can i drive down for a quick spin?
Old Oct 21, 2008 | 04:44 PM
  #97
conan's Avatar
sounds alot better now. Now go get it tuned and you'll hear it get better and better every pull they make.
  #98
when she is all done sure, we can all go out for a night on the town
Old Oct 21, 2008 | 04:55 PM
  #99
Nimitz87's Avatar
don't get on it still...glad your figuring it out but take it SLOW.
Chad
Old Oct 21, 2008 | 05:06 PM
  #100
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I would have suggested ether but wasn't sure they still sold 'starting fluid' anymore.
You need to borrow someone's scanner/hpt/efi l/autotap/tech 2 and see what's doing.
